Anyone care to run over this paint thing.
(1) Celly paint.....polish up or finish with celly lacquer? .......true?
(2) Can celly be lacquered with 1k and /or 2k clear........true?
(3)1k paint mixed equal with 2k thinners needs 1k or 2k clear lac....true?
(4) 2k basecoat can be left off the gun as lac is in it........true?
(5) Celly can go on top of 2k primer....?
Is gravity fed Sealey Gold Series high pressure 1.4nozzle gun any good ........cos I got one. Maybe keeep it for primer and get a goodie?
Thanks in Advance
Alex
[Edited on 3/6/07 by Alex B]
1/ True (getting difficult to obtain tho)
2/ True
3/ maybe!
4/ False
5/ True
All in IMHO mind, check with your paint supplier before buying anything
Sealey gun is decent enough for top coat, although maybe needs a bigger needle, depending on what paint you will be using.
Hope that helps
Alex
Getting back on to this guys. Can you polish up a paint ....celly or 2k with G3 and then lacquer after it?
Alex
You can do what you want to paint, but you should use a base coat for a lacquer finish if you want a lacquer finish.
