1) Has anyone got a pic of the cutting with an angle grinder? i just want to make sure i am doing it at the right angle (i suspect not)
2) What settings should i start my mig welder at for 25mm steel?
I want to do some practice and hopefully start the chassis tomorrow (just need to brush up my unused for 2 year skills)
Cutting is best done at 90 deg. Cutting disks are not designed to take sideways pressure.
P
25mm steel thats going to be one heavy chassis if its 25 mm box section what is the wall thickness ?
Set it high and work your way down till you stop blowing holes. Without knowing how powerful your welder is the question is a bit vague.
sorry its a clarke 151te
Would guess at just under 3/4 power with that welder on 2mm. Get some cuts and play with them for settings. Nice wee welder that for a budget unit.
Alex
im using the 151te and have it set to max and positon 2 on the next switch and wire speed set to 7 gas set to between 3 and 4 this set up suits me
and i get good results with practice bits i have doneand it does sound like frying bacon when i am welding. i am only tacking my chassis at the minute
so this may change
ps i am no expert so someone may come along and say something different
Thanks guys. Davie H, i actually used those settings and they work well, thanks
