Need to put a small set in some 25mm ali tube I have. Anyone know anywhere around Southampton/Pompey are athat will do this for a beer?
Ian
Ian
You should be able to do this yourself with a bending beam.
You will find pictures of mine in my archive. Really easy to make and will bend one inch steel tube without kinking so aluminium will be a doddle.
atb
John
Ali is like copper when being bent, needs to be fully supported, Steel dosent becuase it has a much thicker wall and different properties.
If only it was that simple Id have done it! If I bent it as you suggest, it would kink!
Thanks for the reply though!
fill it with sand?
Originally posted by scottc
fill it with sand?
<<<<< I'm with stupid!!!!
Thanks for the help guys!!
A 22mm plumbers bending spring should give you enough support.
pipe bending spring from any good plumbers merchant. 25mm only a few quid
Am aware of 15/22/28. Didnt know there was a 25??
oh yeah, sorry, i got one for my 25mm steel tube, remembering it was a nice snug fit inside the tune, but forgetting of the tube wall thickness, and that the id will be smaller that 25mm...
quote: If only it was that simple Id have done it! If I bent it as you suggest, it would kink!
Hi Ian
It really is that simple. You are quite right, tube as opposed to pipe does need support all round otherwise, it will kink. The beauty of the bending
beam is that it really does give support all round and you can bend with an infinite number of radii.
Unfortunately, I do not have any 25mm round tube in stock but I do have a short length of square 1.5mm wall and I have just bent this very easily. I
hope the attached picture will show it. I cannot post multiple pictures but I'll put a few more in my archive.
I hope you manage it alright.
atb
John
Sorry Ian I forgot to reduce the file size. Hope this works now
Cheers all, much appreciated!
