GRP
Alex B - 7/10/07 at 05:33 PM
Have made a mould for bonnet. Going to lay it up. Car will be predominately blue but aint picked a colour as Iwill spray everything at the death.
Is plain gelcoat as good as anything to lay this up in or would it make painting any easier by laying in a certain colour?
Alex
Hammerhead - 7/10/07 at 06:09 PM
MK told me that white was best if I want to paint it. I guess that clear coat should be ok but I have no experience of it.
Mark. - 7/10/07 at 08:53 PM
If you use a similar colour for both the gelcoat and undercoat as you want the top coat then any chips won't be so obvious.
Mark
Peteff - 7/10/07 at 10:39 PM
If you're priming it it shouldn't matter what gelcoat you use.
Alex B - 7/10/07 at 11:10 PM
Ok .........clear it is . will use 2k primer. Cheers
Alex
Phil.J - 8/10/07 at 08:02 AM
If you use a pigment to get a uniform colour, then any flaws will be much more obvious. easier to fix then before you apply paint.
Alex B - 8/10/07 at 09:43 AM
I do have Aircraft Grey pigment.........Mmm
Alex
