Just bought some electrodes for my rehmann tig and i think i've got the wrong ones, green tip 100% tungsten I've ground a point on them. But
am led to believe that green electrodes are unsuitable for DC and shouldn't be pointed, can any-one confirm if I can use them or do I have to go
and buy some more if so what do I need.
Tony
I use ceriated for everything, no problem. Thoriated are DC only, red tip and there are gold tip multi strike for AC/DC I think they are Lanthanated. Thoriated are slightly radioactive.
I bought some 1.2mm ceriated and I'll happily post you one if needed as I'm probably never going to use Tig, and if I do I've got 9
more I can use.
1.2mm is a bit small probably for what you need.
