I am playing around with some copper pipe and steel plate to make a manifold for an experiment with bike carbs. I was thinking about brazing these
together using my TIG inverter. Anyone done TIG brazing and can give a few tips or hints?
Caber
Use TIG Brazing Rods??
I saw some so I got them, as they have to be useful.
However, not had anything to try them on.
Well... Yet!
Hi,
I think TIG brazing of Copper to Mild steel plate (5mm plate ?) Will be a difficult task to achieve. I cant see you maintaining the right heat in both
parts.
I assume this is for a water cooling pipe pick up.
You could Tig weld a small length of Mild or stainless steel tube to the plate instead of a copper tube.
Presonally I allways use Silver solder for this type of job.
But I do have the luxury of a gas flame
Ronnie
Probably not an immediate issue but copper and steel do react over time.
At work i've seen copper pipes that have been rested on angle iron hangers and eventually it corrodes through the copper.
it wont work sorry
why dont you do it in steel
I would do it in steel if I could find about 500mm of 40mm thin wall steel tube!
If I can't TIG braze I suppose I could solder them together
Caber
Originally posted by thunderace
it wont work sorry
I've done a bit of TIG brazing , great not having to clean the flux off.
Wimmera
