I just bought myself a rivnut tool but it has no instructions. I have been trying a few blanks on some scrap. My question is: How far should you pull? Its not like a pop rivet where you break the end off so how would you know how far to pull the thread till it secures in place?
There is normally a screw to prevent pulling too far, you set it once you have got it right.
I go by force, it is quite hard to damage steel rivnuts, ali it is quite possible.
Darren
certainly with the ones I've tried the tool 'automatically' snaps in half with a loud bang preventing the rivnut becoming too tight,
which is fine if you have only one to fit
hi, screw the rivnut onto the thread until the end is flush,insert in hole(fnah,fnah)squeeze handles initially they will be quite easy and then you
meet more resistance this is the time to stop,slow and steady wins the race wayno!!!
ok thanks, So there is no setting to use depending on the thickness of the material you are riviting in?
no not really, you can tell when they go tight, the thing is when you bolt the final fitting on, say a skuttle, the rivnut just tightens up even more so it should never go slack, fool proof.
When the tool strips the thread in the Rivnut, that's just too much force
Seriously, if you take it easy, you can feel the Rivnut deforming and then it gets tighter. That's the moment to stop.
Just one point about rivnuts make sure you buy the serrated ones, as they fold the serrations grip the metal preventing them from spinning, the plain
shank ones tend to spin
Tony
just my opinion but i think riv nuts are poo I always weld a nut into the rails!
