My driveshafts are attached to the diff using a star shaped head.
Can you get a star shaped socket for it? if so where from because ive tryed with a normal socket but it starts to slip and im worried about ruining
the bolt head completly.
You mean Torx drive i think (there are male and female versions). Halfords sell decent sets.
male
torx
female
torx
theyre the ones cheers
if its a sierra diff with female torx cap screws the size you require is
T45
cheers les g
ps
did you find the bits on haynes of any use
that i u2u,d you
The Torx heads will probably mash when you try and get them out - if neccessary gtind off the heads and then replace with allen bolts.
