I see lots of wood mitre saws in B&Q and places like that, but are there metal cutting mitre saws available?
or a tool to mount an angle grinder in it?
Have a look at the metalwork section of machine mart
search evolution ragehttp://www.evolutiononline shop.com/store/shop.cfm/ses_/c,custom,x,3,3000,x/Evolution%20Rage%203/Rage%203%20%20Saw/
PS - Apologies for the multiple entries (ooer
). Computer had a 'moment'
[Edited on 17/6/08 by StevieB]
i bought the rage chop saw 355mm very good machine
rage chop saw
[Edited on 17/6/08 by macspeedy]
There's a pile of metal cutting mitre saws at my local Netto, £80 each I think...
Don't buy an angle grinder stand - complete waste of space!!!
Available free to collector: Angle grinder stand.........
I've got the Netto one. They'd reduced the price to forty quid. It's a bit crudely made particularly the angle calibration but it does the job. Done loads of mitred joints for railings already. Comes with spare brushes as well.
you can buy two main types one which is like a larg angle griner with a massive cutting disc the other is low speed with a standard type of blade. The first type kicks out dust like its going out of fashion so recommend a mask
the angle grinder attachments aren't great (i've got one) but they aren't terrible.
If you need okish cuts quickly they work - biggest problem is the disks soon get eaten up by the metal so it will only go 3/4 of the way through the
box, you then have to turn the metal and cut again.
I've had mine do repeated cuts to close enough to 90 degress to be able to weld (yeah ok, not perfect but a small gap helps penetration!). When i
cut i hold / push the grinder to the left to take up any play instead of just using the nice useless handle.
Although for anything delicate / accurate / not 90 degrees i get out the hack saw.
