hi all, is there a special tool you use to adujst the shocks with?
if so where do you get it from?
thanks
stuart
C spanner.
Try Demon Thieves etc etc.
Or just jack the car to take the pressure off and do it by hand.
I've havd the same prob. a c spanner does not fit correctly so use a alligator wrench.
Or as previous try taking the load off which is the easiest method even if you have the correct spanner..
yeah, i got mine from the protec stand last year. It fits. I turned mine by hand to start with, car jacked up so wheels were off the ground, but needed a bit more so got the spanner
have a look in the for sale section, some in there for £5.
i have put my name down for one, just need make sure it it is a 1.9 not 2.25 tool i need.
stuart
