For any-one who's never seen one this is the gunson eezibleed great for bleeding brakes and clutches on your own.saves those wonderfull arguments
with the wife.you know the one (I Said hold the pedal down) just fill the bottle with brake fluid connect cap to master cylinder and black pipe to
spare tyre at about 20 psi and now open the bleed nipples in turn, no need to use the pedal
The black pipe in the picture has an air line fitting cos I have one in the workshop, the other one I have has the standard tyre pump fitting
[Edited on 4/9/08 by mad-butcher]
This is one of my top ten favorite tools, i hate bleeding brakes and this takes all the misery out of it.
Best to give the pedal at least one pump or you may find air trapped in master cylinder.
Tip when using the eezibleed is if you have normal rubber covered brake flecxi hoses, use a hose nip/clamp to control the flow then you can close
the bleed nipple without having to rush.
Impressive....off to Screwfix to spend my £14.99
As said by britishtrident best to press the pedal once or twice, please remember to shut all nipples and release the pressure in the bottle before
unscrewing the master cylinder fitment unless you want your beloved bodywork covered in brake fluid. If this tool has a draw back it is that it fills
the master cylinder to the top so you have to remove some of the fluid to put the top back on, I used an old printer refill hyperdermic to remove
excess fluid to get it to the max mark
Tony
The locost method I use is just a simple length of suitable clear tube with a bung in the end and a small slit in one side .
The slit acts as a one-way valve , the bung adds weight to keep the tube in the jar - all you then do is loosen the bleed screw , and pump the pedal
till no more air comes out (while keeping an eye on the fluid level in the master cylinder....)
Total cost - nothing
The slit acts as a one-way valve , the bung adds weight to keep the tube in the jar - all you then do is loosen the bleed screw , and pump the pedal till no more air comes out (while keeping an eye on the fluid level in the master cylinder....)
same here I find that to be easier than having to connect all the pipes to a pressure source. I have tried both and he pipe with the slit is easier overall.
