I'm preparing to panel the Trials Car and needed some information on rivets particularly for the floor. I spoke to Primary fasteners who are
extremely knowledgable and helpful. I thought the following information that I gleaned might be of interest so, here it is.
All pop rivets are Imperial so Imperial clearance drills should be used to ensure a tight fit. These are
3.2mm rivet use 1/8 drill
4mm rivet use 5/32 drill (yes, I know 4mm is identical to 5/32)
4.8mm rivet use 3/16 drill.
Sealed aluminium rivets have a greater magnesium content and are therefore stronger than the non sealed ones.
8mm long rivets grip 1-3mm
9.5mm " 3-4.5mm
11mm " 4-6mm
I hope this is of interest.
John
Useful info - thanks
Added to bookmarks
very usefull.
did you get any prices aswell?.
I did indeed!
4.8 x 11 and 4.8 x 8 sealed rivets are £4.60 per 100 plus carr and VAT
John
great info thanks
as for rivets I use this guyTifosi
