Hi,
I was just wondering whether anyone happens to have a pdf or image file of a wiring diagram for a '98 1.3 Fiesta or knows where I can find one
online.
I'm just trying to trace a fault on my friend’s car that keeps blowing the internal light and clock fuse. Anyone got any ideas of common faults
to check on these circuits?
Ed
The main cause is the cig lighter body, disconnect it from the back & see if that cures it.
Dennis
more than likely its the fusebox itself
Could be both of the above -- however I have seen exactly these symptoms before on a Ford --- prise the courtesy light assembly from the roof lining and look for chaffed, nipped or burnt wiring.
Cheers guys,
I'll pass that on.
Ed
