I tend to be a one-man band. Anyone using one of these?
What type/model are you thinking of? To really be of any use you would need a decent (expensive) one.
as above, there are at least 2 ways of measuring, and one using 'abs ring sensors' would be very unlikely to work well on circuit
racing.
reason being: they count the tyre revolutions and compare to the other tyres.
most TPMS systems use 433mhz transmission. You can read the output on a 20 quid usb tv reciever. If the manufacture transmission has been decoded you
can get tyre pressure and temperature.
(look up rtl_433 - open source software).
A little more detail to my previous answer
Anyone that knows me will say I am not one for blowing my own trumpet. Along with my team of staff I have designed, developed and manufactured TPMS
systems for over 20 years now and for the last 18+ years all for a leading tyre manufacture for one of the harshest uses in the world (it makes F1
look like a breeze)
I tend to be aware of most reasonable systems on the market, always keeping an eye on the competitors
To get any sort of useful pressure information you will need to spend at least £500 IMHO (probably twice that) and this being a locost forum I suspect
that is over your budget? The lower cost systems just will not give accurate (or repeatable) enough information for track work.
The valve screw on types can cause air leaks as the thread form on the outside of a schrader valve is often very poor (low cost), it is designed to
keep a valve cap on not keep air in!
If you think you have found a system that will work for you let me know and I will tell you what I know about that system
Sorry to hijack this thread, but Pete may know the answer to my question
Pete, why are some TPMS systems so bad, I work for an Insurance/car rental company, and doing so drive brand new cars
all the time, the worst brands for TPMS faults/errors are BMW and Honda, both of which have to go back to the main stealers to be rectified, just
wondered if they use the same system ? as I can not recall any other brand of vehicle that has had any faults
And we have pretty well everything from Nissan Jokes to Bentley's
steve
all the time, the worst brands for TPMS faults/errors are BMW and Honda, both of which have to go back to the main stealers to be rectified, just wondered if they use the same system ? as I can not recall any other brand of vehicle that has had any faults
steve
Originally posted by peter030371
A little more detail to my previous answer![]()
Anyone that knows me will say I am not one for blowing my own trumpet. Along with my team of staff I have designed, developed and manufactured TPMS systems for over 20 years now and for the last 18+ years all for a leading tyre manufacture for one of the harshest uses in the world (it makes F1 look like a breeze)
I tend to be aware of most reasonable systems on the market, always keeping an eye on the competitors![]()
To get any sort of useful pressure information you will need to spend at least £500 IMHO (probably twice that) and this being a locost forum I suspect that is over your budget? The lower cost systems just will not give accurate (or repeatable) enough information for track work.
The valve screw on types can cause air leaks as the thread form on the outside of a schrader valve is often very poor (low cost), it is designed to keep a valve cap on not keep air in!
If you think you have found a system that will work for you let me know and I will tell you what I know about that system![]()
What's the limiting factor Peter? Seems like MEMS pressure sensors are likely to be pretty fragile for in-wheel mounting. I'm curious about the technical problems (purely from an academic standpoint)!
Originally posted by JMW
What can you tell me about the Carchet TPMS model CQ575 please?
If use two sensors on wheel maybe will have more accurate reading (on wheels who have two stems)?
p.s. just kiding
Originally posted by fregis
If use two sensors on wheel maybe will have more accurate reading (on wheels who have two stems)?![]()
p.s. just kiding![]()
What level of information accuracy are you looking for? My neighbours Toyota sensors report pretty consistent results. If you got some tpms valves
fitted, then took readings to calibrate what it reported against your normal pressure guage - would that be close enough?
(I'm assuming you can fit the sensors to any shell when you change the tyres.
NB. Consistent means I got the same pressure within 1/2psi every day - I guess in reality the pressure for be changing but the sensor isn't
reporting it
Originally posted by MikeR
What level of information accuracy are you looking for? My neighbours Toyota sensors report pretty consistent results. If you got some tpms valves fitted, then took readings to calibrate what it reported against your normal pressure guage - would that be close enough?
NB. Consistent means I got the same pressure within 1/2psi every day - I guess in reality the pressure for be changing but the sensor isn't reporting it
It has been tried for critical applications but if you get two different readings which do you believe?
Having had cars with TPMS and cars without I'd go without. My wife's Honda Civic Tourer has warned about TPMS pressures on and off since new, nothing the Honda garage does seems to fix it.
I'd the sensors are producing a reading, then I'd be willing them to replace the sensors which I imagine they're reluctant to do.
