I am having one of those moments where I am overwhelmed with choice..
Anyone have any views...
New kitchen going in shortly... but what to put on the floor..
Tiles, stone, vinyl, laminate.... none of the above?!?
Obviously want to keep the cost as low as possible, but it needs to be durable and easy to clean... what do you have?
We have stone tiles, and thats how we/i like it,
personley i would not have laminate, or plastic floor covering, or even carpet
Downside to having stone tiles, is when you drop your favorite mug, it smashe's
Do you not find the stone a little cold? (unless you have under floor heating?)
We have a tiled kitchen floor and don't really find the floor cold. It does have approximately 100mm of concrete beneath it which insulates it
quite well and we've never had to consider under-floor heating.
Like Steve M says though, most things that you drop on it smash. Even expensive crystal wine glasses
Looks as good today as it did when I laid it about 11 years ago and is easy to clean.
Phil
As Hellfire said, i dont think its cold, and its not heated
Large tiles, without underfloor heating you do not know what you are missing... its brill.
Make sure they are bedded in well, cracked tiles are a PITA, this is not a cheap way to go.
dark tiles an grey grout, pale tiles and pale grout always look dirty, made that mistake and had to rip and replace once before costing £££ as the
heating gets destroyed in the process.
Stone tiles are the best, it`s just my opinion but I have tried laminate flooring in the bathroom & I wouldn`t touch it with a barge pole EVER AGAIN! Dennis
i have tiles in mine and it is very cold and unforgiving. Mine has air space below with no insulation at all, hence the cold. If i redo, it will
definately have good insulation and underfloor heating. I suspect i would do tiles again. It does annoy me that they break anything that falls on
them, but i suppose thats par for the course really. The granite tops are just as bad.
One big issue for me is draughts, make sure when the units are out that EVERY gap is filled, nowt more annoying than a nice new kitchen with bloody
draughts out of the doors.
garage floor paint,that comes in various colours
Originally posted by westf27
garage floor paint,that comes in various colours![]()
I like your thinking.... Non slip... easy to clean...
Heheeee
I echo the advice to avoid light colour grout, it will quickly look like (not very nice)
Other question is whether to tile before of afterwards.
Tile before uses more tiles, tile afterwards means you can't change the kitchen layout if you want to, and if the appliances aren't
integrated getting them out might not be so easy (depanding on the tile thickness and the worktop height)
May not be the cheapest solution but I fitted solid wood oak flooring. Warm to walk on and some give when dropping items on it. Can be sanded many times. Can be sourced on internet for not much more than good tiles.
My you're a clumsy lot!
first figure ...
out how long you're likely to stay,
how much you want to spend,
how long you're likely to keep the flooring,
how likely what you're going to fit is going to date
how likely the other half will want something different in x years.
once you know that, you'll rule in / out a few options and hopefully make the decision a little easier. I've got cheap laminate, its been
down 10 years and has chipped in lots of places. Plan is to throw down some vinyl at some point.
Looking at the prices of various things it seems that a travertine effect floor can be fitted for about £8/sq meter.... Thats a lot cheaper than "good quality" vinyl flooring... Not sure what the quality of the tiles will be like, but they should be hard enough not to fall appart on me! I hope..
I have ceramic tiles bonded very carefully to avoid any air gaps on my solid concrete floor.
The whole floor was tiled right to all the edges before the kitchen went in.
As said above they are grouted with a dark cement based waterproof grout that has now been down over 10 years and still looks as good and does a good
job in the kitchen.
If I was doing it again now I would install a better base, ie: 100mm concrete, 100mm celetex or kingspan with 50mm screed embedded with a wet
underfloor heating system.
I am seriously considering updating the dining room floor with the above system but the thought of the mess is making wor lass shake her head. She was
the one who suggested it in the first place!
Serious point - ensure whatever covering you use can't be damaged by stiletto heels (rules out those Sat specials then Teg!).
The laminate flooring we used in our flat was seriously damaged by a rather large lady who had a penchant for high heels.
Loading is in terms of tons per square inch!
HTH. Cheers, Pewe
Siple, replace any dodgy boards, make sure they are well screwed down, I plane the high edges if needed then use "tile on wood" stuff.
Brilliant, been down a good few years now in kitcen and bathroom, suspended wood floors. The grout had a "pva" based additive to prevent any
cracking. Works perfectly.
As to the step, a bit of hardwood, finishes the job nicely.
