Hi i need a cam belt kit for my st170 engine ..
Some sites sell a kit i have never seen they list it for the st170 others the sell the same kit as a blacktop zetec for it ..
Looking at pics of the st170's the tensioner pulley ect look same as a zetec
Anyone know for sure ?
Ryan
[Edited on 21/2/13 by monck]
Why not go to your local Ford emporium and buy a genuine kit for an ST170. In my experience Ford prices are very little more than factors and you get the same OEM quality fitted new. Would never buy something as important as a cam belt off a website, probably a cheapo plasticine copy.
I think you've missed the point of my question im not trying to by a dirt cheap part ..
I actually have a genuine new kit for a blacktop zetec hence the question ..
And as a ST170 IS a zetec block its reasonable to think there the same
My local Ford parts place want over £100 for the kit that's more that half of what i payed for the engine
All i want to know is if its the same ? Some company's/motor factors tell me the blacktop zetec kit fits st170 also , Others say i need a
diff-rent kit in which the tensioners look nothing like the ones fitted to a st170 ..
So which is right im away from my engine at current so cant compare the blacktop ones i have
Ryan
You said in your original post "Hi i need a cam belt kit for my st170 engine .." but now you say "I actually have a genuine
new kit for a blacktop zetec hence the question ."
How is that the same question.
The answer is still pretty much the same, ask your local Ford emporium if the same part applies to both engines.
With regards to cost if you are quibbling about £100 for a cam belt you have the wrong hobby. Ford recommend changing every 10 years, that's £10
a year or less than 2 gallons of petrol.
As I remember you destroyed your brand new Blacktop recently because you saved money in the wrong place, surely you don't want to do it again.
Do it right and do it once.
Paul i do apologize for the first bit as i did not state i had a blacktop kit your right but i was just trying to find out if it was different if it
wasn't i would have used this ..
Regarding my blacktop i had a sump made yes (You may view this as cutting corners) But it was by someone who makes loads on this site as me like alot
on here cant justify £500 quid on a cast Raceline sump even if we would like .. (Im the only person that's had trouble )
I do disagree about non genuine parts but im sure as you say there are some "Plasticine copys" also. ..
But for example over the years i have bought a few drive-shafts all non genuine ones at around half the price and even driving the cars hard i have
never had a single issue EVER!!
Seems maybe we got of on the wrong foot and im sorry if i came across in the wrong way but if i was skimping on things id do what most do and just not
bother with a new belt and tensioner at all ..
Ryan
Originally posted by monck
Regarding my blacktop i had a sump made yes (You may view this as cutting corners) But it was by someone who makes loads on this site as me like alot on here cant justify £500 quid on a cast Raceline sump even if we would like .. (Im the only person that's had trouble )
Ryan
Yes i admit im a rookie compared with you (3 years) But at the time i had people saying they had no issue shorted ones so i just went with it
Im already planning on a scholar sump on my st170 engine and i already have the scholar blacktop kit / wind-age tray fitted ..
Yes i never did know why people spend loads on a water rail when the ford stats no issue ..
Ill go in now with my tensioners and compare but im sure it uses a blacktop kit ...
Ill let you know if it is or not
Ryan
[Edited on 23/2/13 by monck]
Call me old school, but I'd cringe at £100 for a cambelt kit too! (not to mention 250quid for a sump)
My car runs a crossflow and the timing chain rattles. The fact that it still rattles after 2 years shows how much of a tight arse I am, BUT I
don't thing I'm in the wrong hobby.
I take as much enjoyment out of fixing cars as I do driving them and try to adopt the original Locost ethos of making everything you can and if not,
use the cheapest good stuff available (i think I spend too much time researching stuff as a result!).
Kit cars are not for me, I admit, but Locosts most certainly are.
Ryan
Think the ST170 is the same as the black top as its the base that the ST was built on. The problem with Belt kits is the tensioner. Even the Ford
supplied plactic ones fail. Spoke to one engine builder who will not fit belt kits due to the tensioners failing, leaving the owners to fit them.
Uprated tensioner link, not tried them though.
http://www.ikengineering.co.uk/miscellaneous%20components.html
This is the Ford supplied part: Dayco part number is KTB408
