I've been fiddling around with some mikunis on my MGB while I rebuild the SUs. I was interested to see if 2 ZX6R mikunis would work. Problem is I
can't get them to stop overflowing. The float valves seal perfectly if I blow through with them whilst lifting the float or connect them to the
fuel pump upside down so gravity closes them.
I've set the float height correctly but despite this petrol sprays out of a vent at the front of the carbs and floods into the Venturis.
Obviously the floats must not be closing the valves but I can't work out why. The floats appear in perfect condition and move completely freely.
I have the same carbs on my Zetec with zero issues.
Any suggestions?
Stu
What fuel pump are you using?
Electric bike pumps cut off when up to pressure.
Too much fuel pressure.
Yes definitly need very low pressure bike pump or similar else it will force past needle valves
I'm using a ZX6R pump so definitely not that. Also gravity closes the float valves perfectly against the pressure of the pump
Probably one of those that needs a return to the tank and a T-piece used with a restrictor on the outlet to the carb. Regardless of how well it seems
to seal there can only be a few options -
1) Float doesn't float
2) The float does not not close the value when it floats.
3) The pump pressure is greater than the closing force on the needle.
4) Aliens.
Probably one of those that needs a return to the tank and a T-piece used with a restrictor on the outlet to the carb. Regardless of how well it seems to seal there can only be a few options -
4) Aliens.
Just my thoughts, have you mounted the carbs at the same angle as they are on the bike or parallel?
There should be a mark on the float bowl indicating carb fitting angle. Some bike carbs are ok mounted parallel, others not
I thought of that so tried them not mounted on the manifold and the angle they sit at makes no difference
I Tried again after looking at where the floats were on another set of carbs I have that haven't been changed. Seems the instructions for
measuring float height I found online aren't right, but in the wrong direction meaning my floats were set too low.
I set them the same as the other carbs and after a bit of a leak initially they settle down and were barely leaking at all, so definitely progress.
Still can't get it to run right though. I think I'll wait until my SUs are rebuilt
I would have thought most bike carbs could be gravity fed..
If they flood from gravity feed - you got a problem
If they flood from gravity feed - you got a problem![]()
Where do you propose mounting the tank so it can gravity feed the carbs in an MGB?
Can't really help on the fuel leak, but you may want to get one of these BMC Replacement Units for the car. It works great on bike carbs:
Just a thought, are you using a complete set of the carbs, ie: 4 of them all connected as they should be ? seeing as you have another set of them on a
zetec and work correctly, how about using that set up instead to see if any part of that can be ok'd so that you can move onto the next question
part of the setup?
Jason
Originally posted by Deckman001
Just a thought, are you using a complete set of the carbs, ie: 4 of them all connected as they should be ? seeing as you have another set of them on a zetec and work correctly, how about using that set up instead to see if any part of that can be ok'd so that you can move onto the next question part of the setup?
Jason
Oh ok, if your using just half the set of four carbs, the pump may be set to pump enough fuel for the full set of carbs, have you tried to block the
overflow part in case it's used by the set of four carbs to fill the other carbs of the set?
I am using a set of gsxr600 carbs on my newly installed zetec, the carbs were previously used on my x/flow for the IVA test and about the next year
and a half. the same setup works perfectly on both engines and I am using the std bike fuel pump fitted along side the fuel tank and it pumps the fuel
from the back to the front of the locost and fills, and stops perfectly.
Oh ok, if your using just half the set of four carbs, the pump may be set to pump enough fuel for the full set of carbs, have you tried to block the overflow part in case it's used by the set of four carbs to fill the other carbs of the set?
I am using a set of gsxr600 carbs on my newly installed zetec, the carbs were previously used on my x/flow for the IVA test and about the next year and a half. the same setup works perfectly on both engines and I am using the std bike fuel pump fitted along side the fuel tank and it pumps the fuel from the back to the front of the locost and fills, and stops perfectly.
Have you checked all around for possible air leaks, could try a heavier grade of oil in the dash pots?
Update, looks like it could be an air leak between the manifold / heat shield / carb spacer so I'll make or buy a metal heat shield and see how
that goes.
The timing light is actually fine - seems like the MGB ignition system is marginal in it's ability to induce enough EMS if the timing light pick
up to make the light flash. Not sure if that implies a fault in the ignition system or just dirty plugs. Every single ignition component is new though
so should all be OK.
Stu
Well done Stu, as you have a nearly new full ignition system, just a thought, make sure the plug gaps are correct as they would also cause an issue with a weak spark making the engine run badly.
