Author: Subject: How strong is solvent welded plastic?
smart51
posted on 15/11/08 at 04:09 PM Reply With Quote
I've just made a headlight cover out of perspex which I "glued" together using solvent welding fluid. I'm fairly pleased with the result but I don't want to try breaking it to see how strong it is. How strong is solvent welding usually?
Echidna
posted on 15/11/08 at 04:24 PM Reply With Quote
Could you provide the brand of this fluid?
Are we talking about chemical or mechanical bonding? The first is better of course!
r1_pete
posted on 15/11/08 at 04:25 PM Reply With Quote
If the solvent and perspex are compatible, and the solvent has actually desolve the perspex to 'weld' it together, you'll probably find the perspex will break before the joint, it is very strong.
COREdevelopments
posted on 15/11/08 at 04:51 PM Reply With Quote
i used it to glue my spud launcher together as it was made from drainage pipe. it never came apart except for the screw on end cap which shattered after a fair bit of use,
rob
mr henderson
posted on 15/11/08 at 04:54 PM Reply With Quote
Basically the same as welding, need to ensure plenty of contact area and compatible materials
smart51
posted on 15/11/08 at 05:19 PM Reply With Quote
The fluid is called poly-weld. It says acrylic on the bottle and to be fair, it seems to have done the trick.
mr henderson
posted on 15/11/08 at 05:29 PM Reply With Quote
Well, Perspex is acrylic, so that would seem to be ideal
John
[Edited on 15/11/08 by mr henderson]
Lars
posted on 15/11/08 at 10:01 PM Reply With Quote
WOuld this sort of suff be strong enough to change the in/out-let of a car radiator?
posted on 16/11/08 at 10:41 AM Reply With Quote
I doubt if the radiator will be acrylic, you need something like JBweld or Araldite industrial. There's also Devcon which should do it too, try googling round.
