Moorron
posted on 2/12/08 at 01:05 PM |
Exhaust wrap ties
Hi guys this should be able to be answered on here so here goes.
How do you tighten and fix the s/steel exhaust wrap ties? I have wrapped the exhaust manifold up nice and tight but I cant hold the tie tight and I
don’t know how to ‘clip’ it up. The ties I am using are the ones that don’t have multi slots in them like some i have seen, these ones are plane and
slip thru a slot on the end but that’s it.
Also, do you have to apply silicon spray or is this an optional thing?
Sorry about my spelling, im an engineer and only work in numbers.
flak monkey
| posted on 2/12/08 at 01:08 PM |
Put a jubilee clip around them instead
I used the stainless ties on the head end of my exhaust, they dont do up that tight, but have stayed where put for a long time now.
When I re-wrap the exhaust though I will just be using jubilee clips.
Sera
http://www.motosera.com
| posted on 2/12/08 at 01:57 PM |
Yup. Second vote for jubilee clips....
wicket
| posted on 2/12/08 at 03:21 PM |
Stainless steel lock wire.
simoto
| posted on 2/12/08 at 03:30 PM |
x2 nice neat near invisible job with lockwire.
RichardK
| posted on 2/12/08 at 05:26 PM |
Mine had a very small ball bearing that was behind a little tab and what you need to do was put it tight with pliers as they do cut skin (I know) and
then with a small flatblade driver push the tab forward which bends the tab which pushes the ball forward jamming the ball and strap.
The above only applies if mine are the same type as yours
Rich
[Edited on 2/12/08 by RichardK]
Gallery updated 11/01/2011
Moorron
| posted on 3/12/08 at 01:27 PM |
cheers for the replies. no my ties are different and dont lock in any easy way. I didnt even think about using locking wire, i suppose i could use
some stainless steel tig wire which i have loads of.
so, just the question about the need to spray it with silicon? does everybody here do this?
