RickRick
posted on 17/8/09 at 06:48 AM |
Sealing aluminium drysump oil tank
We're having problems with oil leaking from the drysump aluminium oil tank, looks like it's coming from the welds in one or 2
positions.
We've tried some sealant on the outside but that's not made any difference.
all suggestions welcomed!
tomgregory2000
posted on 17/8/09 at 07:17 AM |
weld up the holes?
RickRick
posted on 17/8/09 at 07:24 AM |
it's the seams that are causing the problem, and we won't be able to get it re welded untill after the next 2 meetings, so we're
looking for a more temp fix really
sorens2
posted on 17/8/09 at 08:24 AM |
Liquid metal.
Or whatever it is called.
Like toothpaste but turns into metal.
Remember to clean it with brakecleaner or so.
Soren S2
posted on 17/8/09 at 09:30 AM |
lumiweld would be quite good as it would flow into the gap ... you would need to cean the joins thoroughly.l
posted on 17/8/09 at 10:28 AM |
Yes- good option Clean out the welds, scrub the outside with the stainless steel brush then wallop on some lumiweld / technoweld. Should work very
nicely indeed!!!
RoadkillUK
posted on 17/8/09 at 04:00 PM |
Might I point you to this thread?
LINKY
It's for a wet sump, but I'm sure the tecnique would be the same.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
