| posted on 10/9/09 at 09:38 AM |
moving a hole?
I have a chunky piece of steel, maybe 10 mm thick or more - this is the crossflow alternator bracket - and i need to move it back. It is held on by
two 3/8 in UNF bolts.
this involves changing the potision of two bolt holes so what is best way to do this?
file them out and attempt to plug well the gap? or plug weld and drill new holes - bearing in mind that I hve fold welded steel to be tougher than
mild steel - tempered due to heat?
not sure how effective my MIG will be with such thick metal but the steel will only act as a spacer - or will slotted holes be ok?
and fill the gap with metal filler?
rallyingden
| posted on 10/9/09 at 10:01 AM |
How far are you moving them ?
RD
designer
| posted on 10/9/09 at 10:04 AM |
10mm thick??
| posted on 10/9/09 at 10:07 AM |
RD
about 5 mm.
Mr Whippy
| posted on 10/9/09 at 10:14 AM |
10mm thick metal is hardly an issue unless your welder is powered by AA batteries.
Clean the hole and weld it up. If you then reheat the bracket with a blow torch till it’s glowing, then leave it to cool down, all tempering will be
gone and redrilling will be easy.
rallyingden
| posted on 10/9/09 at 10:16 AM |
You could weld a washer in the new position. Clamping of bracket would be done by bolts, lateral movement controlled by the washers.
RD
[Edited on 10/9/09 by rallyingden]
tegwin
| posted on 10/9/09 at 10:18 AM |
Just go for the bodge job of making the holes larger until they lign up properly
www.verticalhorizonsmedia.tv
| posted on 10/9/09 at 10:26 AM |
hmmmmmm...... I have to admit, that is the way I am thinking. There is no to/fro force on the bracket and the 2 bolts done up tighlty should clamp it
in place.
| posted on 10/9/09 at 11:10 AM |
Exactamundo - slotted holes should be fine and far, far less work. Once installed you'll not see it anyway.
iank
| posted on 10/9/09 at 12:52 PM |
Make a slotted hole, if anyone asks it's for adjustment.
Anonymous
MikeRJ
| posted on 10/9/09 at 03:53 PM |
There is another option; rather than completely filling the existing hole with weld, you could simply plug it with a suitable bit of steel and hold it
in place with some weld at either end. You can then drill a new hole which will partly be into the plug.
I only suggest this as drilling a neat hole in 10mm steel is somewhat easier than making a tidy, straight slot by hand with a file.
A 3/8" UNF clearance hole will be around 9.8mm by my calculations, so you could use the shank of a 10mm bolt to fill the hole if you can turn it
down slightly, or drill the existing hole out to 10mm.
[Edited on 10/9/09 by MikeRJ]
