omega0684
| posted on 22/10/09 at 04:25 PM |
pinto cambelt tension measuring tool
afternoon everyone,
I have been in the garage this afternoon fitting a new cambelt to my pinto after its rebuild and have come across a stumbling block,
the haynes manual says that i need a special 'Ford' tool that measures the cambelt tension, obviously so that the cambelt is the right
tension when fitting is complete. it says that the values on the tension meter for a new belt should be between 10-11, 10-11 what? is this just a
universal scale that the meters use?
where can i get this tool from or does anyone have one i can borrow for the day?
All the best
Alex
Breaker
| posted on 22/10/09 at 04:31 PM |
I have never used this kind of tool, but I do this check:
On the longest "pulling" side (side where the camshaft is pulled by the crankshaft), take the cambelt in the middle between thumb and
index finger. Without too much effort you should be able to twist the cambelt by 90° (no more, no less).
Hope you understand my description...
Edit:
But first spin the crankshaft a couple of turns by hand so the cambelt can settle a bit.
[Edited on 22/10/09 by Breaker]
omega0684
| posted on 22/10/09 at 04:39 PM |
yeah thats what it says to do in the haynes manual, but then says at the first available oppotunity take the car to a ford dealer to get the cambelt
tension checked and corrected if necessary
flak monkey
| posted on 22/10/09 at 04:57 PM |
NO need the 90 deg test is good enough.
Sera
http://www.motosera.com
Breaker
| posted on 22/10/09 at 05:27 PM |
Of course the Ford stealer will be more than happy to do this for you ! £££
omega0684
| posted on 22/10/09 at 08:04 PM |
cheers guys
twybrow
| posted on 22/10/09 at 09:18 PM |
Alex - I have a belt tension tester if you wanna borrow it. I got it free, and I've never used it, but you are welcome to have a play if you
want!
