orton1966
posted on 11/12/09 at 09:06 PM |
Bargain Tube Roller
How’s this for a bargain then?
[img][/img]
I needed to go to the States this past week and whilst there I picked up a Tube Roller from Harbour Freight, on offer, price $160. With current
exchange rates that’s about £100
Whilst I appreciate Harbour freight doesn’t have the best reputation for quality with this I am well chuffed! Three sets of rollers from 1” – 2”
strong construction, bearings where I would expect them. I did read one or two reports about it being hard going on larder diameter tube but I believe
this is probably because the distance between the two bottom rollers is relativity small. So if this becomes an issue and it might not, I will either
drill holes for the shaft further apart or worse-case have two new side plate laser cut, cost a few quid!
Really the above is splitting hairs, compared with the options available in the UK, (Scott roller or pro-tools) I’ve saved about £6-700. Yes, yes, I
know we’re not talking the same level of quality but for a few amateur projects I’m sure it will do an equally satisfactory job. I even looked at
making my own and couldn’t get the rollers turned up for what I’ve paid.
Sorry for the length of this post but I’m well chuffed
liam.mccaffrey
posted on 11/12/09 at 09:15 PM |
did you carry it back with you? As some will know I had a pro-tools bender shipped back some time ago
Build Blog
Build Photo Album
jacko
posted on 11/12/09 at 09:16 PM |
Very good
Where do you live so i now where to come for some tubes to be bent
mangogrooveworkshop
posted on 11/12/09 at 09:18 PM |
You are my new best friend
smart51
posted on 11/12/09 at 09:19 PM |
remember you can roll tubes in several passes so if it is hard work, just roll in the radius a little at a time.
edit: can you fit another one in your case for me?
[Edited on 11-12-2009 by smart51]
COREdevelopments
posted on 11/12/09 at 09:25 PM |
And me please.
Rob
orton1966
posted on 11/12/09 at 09:27 PM |
yes and Nottingham
Yes, I was travelling with a business partner and we spilt the weight between our checked-in bags. We packed a little light on the way out and so even
with the extra weight of the roller we came in just on our weight limits, it weights about 35kg so obvious our carry-on was a little heavier than
usual!!
I’m located in Nottingham if anyone fancies a go
locoR1
posted on 11/12/09 at 11:03 PM |
guess what ive just finished making! mines cost me about £60 in parts but can only do 2" tube unless i make some more
rollers!
Still it was fun making, kept the winter blues away for a few weeks
That is an absolute bargain! can see why your chuffed with it
Here's mine more pics in my archive
Check out my CB500T Cafe Racer build diary
orton1966
posted on 12/12/09 at 07:10 AM |
Nice Job
Very nice job. Like I said I was all set to make my own too but I had no way of making the rollers my self and so would have had to pay someone to
make these for me.
That said I like the fact yours is a little wider because I think this takes some strain off the clamping and rolling components when doing larger
diameter tubing. So at some time in the future I might make some new side plates with several holes to allow me to move the bottom rollers further
apart when required.
What you making, something Atom style?
[Edited on 12/12/09 by orton1966]
splitrivet
posted on 12/12/09 at 10:16 AM |
Its now gone up $19 but the rollers on thier own are much cheapness http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=99736
Bob
locoR1
posted on 12/12/09 at 11:16 AM |
Could be its a secret or was wont be starting till the summer got to many other things on just now!
Badger_McLetcher
posted on 14/12/09 at 12:56 AM |
Ok, this is probably a stupid question, but would one of these be ok for making a roll cage with?
Cause I reckons I can make one of those quite easily, and it would definately be easier to create the differing radii bends on the cage.
I imagine there's no tube collapsing problems as long as you take it slowly?
Badger
If disfunction is a function, then I must be some kind of genius.
orton1966
posted on 14/12/09 at 06:59 PM |
Tube bender V's roller
What you need is a tube bender for smaller rad bends like the corners of the cage and a roller (like these) for the larger rad bends like the side
tubes of an Atom
