zilspeed
| posted on 9/4/10 at 03:51 PM |
Metalastic bush - bolt seized
Any suggestions for getting it out ?
Got the nut off ok.
Can twist the bolt and it will show signs of moving slightly within the inner tube, but not enough to allow it to pull clear.
Can't get in to the end to hammer it out.
Cant really get in to pull it out.
other than burning the rubber part out (which still leaves the inner steel tube seized to the bolt), any suggestions ?
It's currently soaking in gallons of WD40 with a breaker bar holding it under rotation to encourage it to break free.
skinned knuckles
| posted on 9/4/10 at 04:02 PM |
before the health and safety people jump all over this reply, i know its dodgy, but it works really well .
i have an old knackered angle grinder (small size) that i made a small steel disc for. i purposely unbalanced the disc with heavy blobs of weld so
that when its turned on, it vibrates more than the best toys in the amsterdam museum of fornication.
whenever i come across a really stubbun nut, i clamp the grinder to my wrench, near the nut end, turn it on and appy pressure and bingo, job done
if you can get the vibrations going somehow it could help remove the little bugger? especially if its being soaked in slippy stuff.
[Edited on 9/4/10 by skinned knuckles]
A man isn't complete until he's married, then he's finished
tomprescott
| posted on 9/4/10 at 04:03 PM |
Could you use something as a drift to then hammer it out?
If you do burn out the rubber you may find that heating the inner tube will cause it to expand just enough to tap it out from a vice?
A bird in the hand....
Seven_Monkey
| posted on 9/4/10 at 04:15 PM |
Is it threaded all the way down the bolt? I had one similar - just unscrewed from the bush... It must've caught something inside the bush to
help ease it out thread by thread?
ReMan
| posted on 9/4/10 at 04:24 PM |
Use proper penetrating oil, not WD Squirty
Heat it up anyway, if you have the means, that will help
Impact wrench (safer version of the angry grinder trick )
zilspeed
| posted on 9/4/10 at 04:48 PM |
The problem is that the rubber bit just seems to bounce away all of the impact that you can put into it.
will try again, see if I can get into it with the impact now that the axle and everything else is now out of the way.
****ETA****
Nope, nothing doing.
Impact driver turned up to 11 and it's firing away like a machine gun.
All the impact just gets soaked up by the rubber.
Might need to try welding a bolt onto it in order that I can try pulling it out.
[Edited on 9/4/10 by zilspeed]
big_wasa
| posted on 9/4/10 at 05:01 PM |
Ive had luck just spinning the bolt with an impact wrench until it grinds the rust down.
MikeRJ
| posted on 9/4/10 at 05:21 PM |
Air hacksaw. I bought one for exactly this situation.
zilspeed
| posted on 9/4/10 at 05:33 PM |
Now, that would work.
I know I can borrow a reciprocating saw with a hacksaw blade.
tegwin
| posted on 9/4/10 at 07:13 PM |
All of the bushes on my TVR were rusted solid..... you cant get to them to smack the bolt with a drift either...
So.. hacksaw blade, either side of the crush tube... one stroke at a time.... took a weekend to get them out :s
www.verticalhorizonsmedia.tv
hillbillyracer
| posted on 9/4/10 at 07:33 PM |
As an Agric engineer I get stuff like this all the time, we often use the method of welding a fine thread bolt/threaded bar to the head of the seized
bolt, slipping a tube over it that just clears the head of the bolt so it's pushing against the surrounding metal & wind a nut down the
welded on part to draw it out, is that what you were thinking?
If you can sacrifice the crush tube though & have access I'd go for cutting it out.
perksy
| posted on 9/4/10 at 07:35 PM |
Plusgas
Its WD40 on Steroids
austin man
| posted on 9/4/10 at 07:57 PM |
Place a deep socket over the top of the bole aplly a G clamp over the socet and end of the bolt tighten the clamp and press the bolt out. Only works
if you gan get access. Applying oil and heat will also help to do it.
You could also cut the bolt head and drift it out from the opposite side if you have room
zilspeed
| posted on 10/4/10 at 08:02 AM |
Thanks for all the replies folks.
The plan for this morning is to try to press it out using a big socket and a G clamp as decribed above.
If that doesn't work, I ahve arranged a loan of a reciprocating saw and we'll cut the phuqer out
zilspeed
| posted on 10/4/10 at 11:35 AM |
The G clamp bent.
Will be cutting it out tomorrow when a recip. saw is available.
Then I get to practice drilling bolt remains out.
RickRick
| posted on 12/4/10 at 05:38 PM |
i had the same problem on my fiesta but i didn't mind distroying the bottom of the damper as that was u/s anyway so i split open the
"eye" end of the damper to get that out the way chopped up the rubber then drilled and split the crush tube no drilling out required
that way
