Author: Subject: M14 Countersunk high tensile set screws?
alistairolsen
posted on 16/5/10 at 07:21 AM Reply With Quote
I need some of the above, not sure if my terminology is correct but they need to look like this:
Around 40mm long.
If M14 isnt available, any thread I can tap into a similar sized hole and is commonly available will do.
Any ideas where to get some?
My Build Thread
iank
posted on 16/5/10 at 07:32 AM Reply With Quote
Not helpful unless you need 100 and have a good budget, but they certainly exist.
http://www.cromwell.co.uk/QFT6042116G
M14 is too big for relatively rare configuration to be cheap. M12 is the biggest common size (as you can see from the price differential http://www.cromwell.co.uk/QFT6041004E )
A good local fastener supplier should be able to help for smaller quantities.
Anonymous
bartonp
posted on 16/5/10 at 08:05 AM Reply With Quote
Used these in the past (mixed bags very useful) :
http://www.namrick.co.uk/
alistairolsen
posted on 16/5/10 at 09:56 AM Reply With Quote
cheers guys, I know 14mm is an odd size, but they are to go into holes where a hammer fit m12 stud has been......
Hence i dont care about the thread as long as i can get a tap, but the diameter has to be in excess of 13mm.
My Build Thread
