T66
| posted on 10/8/10 at 03:22 PM |
Leak Free Mig Welds - How ?
Ive been making a modified sump to fit on my Fiat 2.0 Twincam, its been chopped fairly radically to fit in the confines of my Lada.
(Yes Lada )
Whats the advice to ensure oil leak free welds ?
Ive reduced some of the leaks with extra weld runs, but its still leaking.
Someone has suggested over brazing to fill the welds up.
Any suggestions ??
PS Lada / Rust & Oil Leak jokes have already been thought of ....
Mark Allanson
| posted on 10/8/10 at 03:39 PM |
Amps up and wire feed down and look closely at what you are doing. I have a pair of +1.50 reading glasses for when I want to get in really close, a
gold EW9 filter will help as it reflects the light back onto the workpiece.
clairetoo
| posted on 10/8/10 at 04:29 PM |
Practice................loads of practice
A big problem with welding sumps (I believe) is that as they are a deep-drawn pressing , they are made from steel with a high lead content (like EN1A)
, so so not weld very well .
I dont think I have ever welded a sump and had it totally leak free
Its cuz I is blond , innit
Claire xx
Will weld for food......
Mark Allanson
| posted on 10/8/10 at 04:31 PM |
I have so ne neny ne-ne
T66
| posted on 10/8/10 at 04:35 PM |
The original TC sump is like you suggest a pressing...
But most of it has been chopped away leaving the flange, and new metal put in.
Putting the volume to the front of the sump, so it clears the Lada diff.
Like this...
http://www.ladaniva.co.uk/baxter/cloggy/fiva4.html
I will have another go, on my days off.
iti_uk
| posted on 10/8/10 at 04:58 PM |
You almost did it with mine - in fact, it's not the welds that leak, it's the awkwardly shaped lip at the back, and the almost-threaded
back two bolts which do it on mine.
:p
Chris
JF
| posted on 10/8/10 at 07:20 PM |
Well a nice and clean surface helps alot. You want a nice even consistant weld. So minimize your stops and anything (like dirt) to intervere with your
welding.
If you have miniature spots still leaking, then try giving it another peck just next to the actual leak. It will often cover it. While if you try to
close it of with welding right on top of it then what caused the original hole will most likely create another.
That's a tip I got from a guy at work who has been a pro welder for years. And seen him do it with a T piece for the cooling system of his
banger racer. Worked a dream.
We do a lot of welding at work, but usually try to avoid having to weld things that need to hold (presurised) oil etc. Really labor intensive.
AdamR
| posted on 10/8/10 at 08:06 PM |
It really must be the material that causes problems as Claire says... I'd describe myself as an average MIG welder and had no probs fabricating
an airtight and petroltight fuel tank.
Dusty
| posted on 10/8/10 at 08:54 PM |
When I did mine I had a few leaks but found it best to dress the weld back hard with the angry grinder in suspect areas. Wipe with cellulose thinners
to clean and put a spot more weld on the holes. Just welding layer after layer without dressing back didn't work.
mark chandler
| posted on 10/8/10 at 09:19 PM |
Mig suffers cold start, this means that the initial start of the weld is porus, when yiu strike the arc the work is cold so the globules of weld do
not stick.
The trick is to start the wrong way, go half an inch then back over where you started carrying on and do the whole thing in one continous weld to
avoid another start.
Alternative is to start the weld on a piece of scrap held against the work then work forward, as you start over the work quickly lift the scrap off,
again a continuous weld back to where you started.
As always, get it clean!
