smart51
| posted on 5/4/11 at 09:37 PM |
How do you push bushes out of uprights?
The bushes on my tin top are like a pair of top hat bushes glued to the crush tube. I want to get them out without breaking them. How do I do this
without a press? Any ideas?
stevebubs
| posted on 5/4/11 at 09:50 PM |
Use a drift to knock out the crush tube?
smart51
| posted on 6/4/11 at 07:17 AM |
I'm pretty sure that would ruin the bushes, given the rubber is bonded to the tube.
MikeRJ
| posted on 6/4/11 at 07:33 AM |
If the crush tube is bonded, how do they get installed in the first place? Is this definitely not a metalastic bush with a steel outer which is
pressed into the upright?
contaminated
| posted on 6/4/11 at 08:38 AM |
You'll never get them out whole in my view. You have to drill lots of little holes in the rubber and then drive it out.
Tiger Super Six Independent
www.southernkitcars.com
tomgregory2000
| posted on 6/4/11 at 08:44 AM |
i wouldnt drill them out, in fact i didnt when i replaced all of the suspension bushes on my defender, i used fire! get a blow torch and burn them
out, much less hassle and much more fun
onenastyviper
| posted on 6/4/11 at 09:03 AM |
Only if you do it in a well ventilated place - the fumes are noxious
smart51
| posted on 6/4/11 at 10:23 AM |
Trouble is I bought the arms and uprights of eBay with new sport bushes fitted. It turns out the wheel bearings are knackered and I would like to
remove the bushes and fit them to my old uprights which are fine otherwise. Removing the bushes without damage is essential. Without removing them,
I can't tell if they have a metal outer sleeve.
PSpirine
| posted on 6/4/11 at 11:51 AM |
Use a hacksaw/dremel/cut-off wheel to carefully cut away at the outright - cut a slot through to the bush's outer sleeve, then just open it up
slightly and tap the bush out?
Upright will obviously be scrap
adithorp
| posted on 6/4/11 at 12:28 PM |
I doubt that they're glued in". More than likely they're metalastic bushes (rubber bush bonded to steel outer)and the outer is
pressed in to the upright. If they are and you get the rubber out then the bush is fubar. Try and press the whole bush out, but you'llbe lucky
to do it without messing it up. If you don't want to ruin the bushes then it might be better to just fit new bearings.
http://jpsc.org.uk/forum/
