scutter
| posted on 11/5/11 at 06:51 PM |
Clarke compressor
I've a Clarke se15c160 compressor to try and get rid off, but don't know the voltage/power supply requirements.
Does anyone know what this is? I'll post in the sale section once i know all the details.
ATB Dan.
blakep82
| posted on 11/5/11 at 07:02 PM |
is it definitely se15c160
could it be se15c150?
if it is, then its the same as mine, 230v, single phase with a 3hp motor, so needs a 32amp supply. got mine on its own circuit breaker and 32amp blue
plug
________________________
scutter
| posted on 11/5/11 at 07:17 PM |
Definately a 160, It a good 8 years old, I think I've found out as it's got a switch box on the top.
ATB Dan.
blakep82
| posted on 11/5/11 at 07:28 PM |
Clarke SE15C160 Air Compressor ( Used ) | eBay UK
seems to be the same as mine power wise.
owelly
| posted on 11/5/11 at 08:46 PM |
Its the same as mine which came fitted with a 13amp three pin plug which runs off my normal ring in the garage!
http://www.ppcmag.co.uk
scutter
| posted on 12/5/11 at 05:02 PM |
It's amazing what you can find out if you read , the plate on the motor says 3hp, 1 phase. I'll post in the sale section then.
Cheers Dan.
