l0rd
| posted on 24/12/11 at 04:38 PM |
black and decker cd115 Angle grinder problem
I got my hands on the above grinder.
Atm, it doesn't work. I have checked the brushes and both seem to have loads of meet left.
How can i test what is wrong with it?
I suspect it is the switch. can i test this somehow before i go spending money for parts?
matt_gsxr
| posted on 24/12/11 at 04:47 PM |
worth taking apart and checking connections. Basically go around checking continuity with you ohm-meter.
I had a Bosch one that has some solder joints that when they get really hot go open circuit. Not sure whether it is a design feature or not. It is
now my "spare", got a new Makita one that is just awesome (if you get money/vouchers for Christmas).
designer
| posted on 24/12/11 at 04:55 PM |
If you take it apart you can bypass switch, be careful, and then you will know if it is the switch or not.
Ben_Copeland
| posted on 24/12/11 at 05:04 PM |
Usually a break in the cable, Couple of grinders i've had have outlived their cables...
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
