| posted on 15/4/12 at 01:14 PM |
Top Welding Tip
I noticed the other day while giving the dash a once over with the back to black it smelled a bit like the anti spatter spray I use for welding.. so,
I tried the back to black on the metal and hey presto! same results.. you just need a lot more of the stuff on, but, at a £1 a go in the pound shop
its a damn sight cheaper than the anti spatter stuff.
The propellent is flammable though, found out after setting fire to me glove but not much. I can put up with that for the cost saving and the ease of
getting hold of the stuff.
Current poundshop stuff is turtle wax 'black in a flash'
jacko
| posted on 15/4/12 at 01:49 PM |
I spray wd40 up the nozzle it helps the wire to come though and stops splatter
tip 2
Jacko
serendipity123
| posted on 15/4/12 at 02:19 PM |
and another tip of the day is here for welding.
serious link
big_wasa
| posted on 15/4/12 at 03:14 PM |
I would be very carfull of what chemical you are vapourising and breathing in.
T66
| posted on 15/4/12 at 03:45 PM |
I have some anti spatter spray, and am not convinced it makes a huge difference.
MIG fumes are pretty blacksnot forming things at the best of times, agreed - be careful what you add to them.
With the mention of wd40 - a reputable fabricator sprays his stainless manifolds when finished and before starting the engine, it creates an almost
titanium finish, once the engine is running and its baked off.
[Edited on 15/4/12 by T66]
| posted on 15/4/12 at 04:02 PM |
Back to Black is silicone based so if you are going to be painting after welding it would not be a very good idea.
