posted on 12/7/12 at 12:38 PM |
Cutting a Thread on 4130 Steel Rod...
I'm looking to get a r/h and l/h thread cut onto either end of a 3/8" 4130 rod.
Before I buy said rod... I guess I should really ask first if this is a fairly straightforward task for a machine shop!?
It's Evolution Baby!
FuryRebuild
posted on 12/7/12 at 12:49 PM |
There are taps and dies for stainless, as I found out when making my sump (tap only).
The shop will probably have what you need, and they may charge a premium because the tooling wears very quickly.
www.furyrebuild.co.uk
posted on 12/7/12 at 12:57 PM |
Cheers.
The other option (cheaper!?) could be to buy 4130 tube instead of rod and weld in some pre-cut threaded rod at either end.
Can't find any 4130 threaded rod in the right size... just stainless or mild steel. Does anyone knows if one is better than the other for
welding to 4130?
liam.mccaffrey
posted on 12/7/12 at 01:21 PM |
I can get you a price for the machine work if required.
its not me but a local machinist, he has done some work for other on here before
Build Blog
Build Photo Album
mcerd1
posted on 12/7/12 at 01:24 PM |
does a certian man not too far from here have any tools do do the job ?
if it came to it I'm sure he could cut the thread with a single point tool on the lathe (not exactly quick and easy though...)
compared to some of the jobs you've given him in the past this would be a walk in the park
[Edited on 12/7/2012 by mcerd1]
posted on 12/7/12 at 01:32 PM |
I'll nip in and ask him at the weekend if I see his van outside.
posted on 12/7/12 at 01:34 PM |
Could you please Liam?
The overall length of the rod is just over the metre mark, and I'm looking for 2-inches of thread cut into either end.
liam.mccaffrey
posted on 12/7/12 at 02:08 PM |
I'm going to see him tomorrow, he should get back to me by the end of the day.
What thread are you looking for?
Build Blog
Build Photo Album
posted on 12/7/12 at 02:29 PM |
Not really fussed Liam... I'd guess that a UNC would be easier!!!???
As long as they're both the same!
Fred W B
posted on 12/7/12 at 03:33 PM |
I must ask, is this for a safety critical part? Cut threads have a stress raiser at the bottom of each one, in a stressed application rolled threads
are much preferable.
Fred W B
[Edited on 12/7/12 by Fred W B]
You can do it quickly. You can do it cheap. You can do it right. – Pick any two.
Neville Jones
posted on 12/7/12 at 04:04 PM |
If it's oversized, then the stress raiser isn't a problem. A solution is to turn a small radius down to the thread root diameter into the
rod at the thread end, to negate the raiser and provide a smooth transition. Done all the time.
Cutting the thread should be no problem using high speed steel dies. I've done it that way for far too many years on high alloy steels, even
stainless. Use a good amount of proper cutting oil, or a mix of candle wax and soluble oil, just like the old fellas used to do it. Some still do.
Thread rolling gear isn't something you'd find in most small workshops. The big mfrs do it because it's quick, saves money, and is
easy on tooling at high production rates.
Nev.
posted on 12/7/12 at 04:49 PM |
Cheers guys.
It is a safety critical part... it's a tie-rod between the left and right upper trailing arms.
posted on 12/7/12 at 05:29 PM |
I should probably add that I planned to drill the threaded ends and use with castellated nuts and a pin.
mcerd1
posted on 13/7/12 at 10:03 AM |
...with a nice big radius/fillet in the corner just to be sure - should look very neat too
good old fashioned engineering
