designer
| posted on 16/10/12 at 10:37 AM |
Compact welding set up
I'm after a compact, portable, set of gas welding gear, anybody had any experience of them.
I know they won't be as economical as larger kit, but I want it for track days as an emergency measure.
FuryRebuild
| posted on 16/10/12 at 11:29 AM |
If you have trackside power, then inverter fusion tig is really compact and robust.
www.furyrebuild.co.uk
mark chandler
| posted on 16/10/12 at 11:32 AM |
Personally I think you would be better off with a small Honda generator and mig/tig invertor.
Carrying a gas set is not going to be great, if you are at any proper track you get electric in the pits.
Regards Mark
dhutch
| posted on 16/10/12 at 02:48 PM |
I expect it would be the rental that would kill it, otherwise the oxy/ace are the same you just have less of them so with a half good torch the
welding is the same as a larger set.
Else, Im very happy with my esab inveter mig set.
Daniel
| posted on 16/10/12 at 05:01 PM |
A small generator will not power a welder. I have a Kemppi generator friendly welder and the minimum recommended is a 5Kva with 8Kva the preferred
output. I have a BOC Portapak oxy-acetylene which is probably more like the original idea. It is handy but nowadays is only used for heating stuck
fixings and welding the occasional really thin metal.
coyoteboy
| posted on 16/10/12 at 05:32 PM |
I LOVE gas welding, such an art to perfect, but I was under the impression that the required safety certs etc pretty much ruled out DIY use above MAP
type gases?
