johnH20
| posted on 5/12/12 at 06:19 PM |
Work gloves
I may be the last person in the ( Locost Builders ) universe to make this discovery but if it helps one other builder out it will not haave been in
vain. I cannot heat my garage and as a result work time tends to become non existant when temperatures plunge. However I discovered a work glove
recently that is good for everything apart from really fiddley things like manipulating nuts in difficult to get to places. They are basically made of
what I think is called stockingette, a loose knitted fabric, onto which a thin textured rubber palm and fingers are moulded. The glove is a good fit
and highly flexible as is the rubber palm/fingers. I got mine as part of a bundle in a garden centre. Highly recommended if you did not know already.
HowardB
| posted on 5/12/12 at 06:28 PM |
Ansell make a fantastic range of these gloves including ones that are cut-proof. I swear by them, and curse when I forget to put them on.
Howard
Proby
| posted on 5/12/12 at 07:13 PM |
I use these at work, and they are great! There are a few different companies that makes them, I think screwfix sell them.
Visit GraphicMonster
| posted on 5/12/12 at 07:16 PM |
If they are the same as the ones I use they are also sold as builders gloves, I get them from the builders supplier for about £1 a pair and use them
for everything except welding. This kind of
thing.
NigeEss
| posted on 5/12/12 at 09:59 PM |
I use Contour
Avenger gloves but I get them in Costco for £15. Builders gloves tend to be a lot thicker.
[Edited on 5/12/12 by NigeEss]
thefreak
| posted on 5/12/12 at 10:49 PM |
quote: Originally posted by NigeEss
I use Contour
Use these too. Much better than the builders gloves.
Was out there this evening. Tshirt, jumper, fleece and drill top. Was quite toasty actually and it was around 3degrees
Mr Whippy
| posted on 5/12/12 at 10:58 PM |
If your cold, get a good thermal boiler suit, I'm working out in the garage, it's snowing heavily, the doors wide open and I'm
cooking with just a t-shirt a jeans on under it.
rodgling
| posted on 5/12/12 at 11:41 PM |
Fingerless gloves are great, a bit 80s fashion-wise but very practical in the garage.
philfingers
| posted on 14/12/12 at 08:00 PM |
Mechanix gloves are great, not cheap or oil proof but can wear them for most tasks, wash well, close fitting etc
The true home of cars born under the Sylva name - http://jpsc.org.uk/forum
STM Phoenix R1
Sold-Sylva Striker 1300xf, 40s etc
Sold-Sylva Phoenix, 1300xf, BVH, 234cam, 2xDCOE 40s, live axle - 'old school', rally car and a few bikes
andylancaster3000
| posted on 14/12/12 at 10:18 PM |
Also swear by the ansell ultra-light gloves. Think they're about £4-5 a pair. Last reasonable time and can be washed a couple of times before
they fall apart.
You really need the ultra-light ones though...
se7en
| posted on 14/12/12 at 10:37 PM |
I use this type of glove as well - they are quite flexable and as JohnH2O says good for doing most garage jobs.
If you are cold working in the garage with no heat, ask the wife/girlfriend for a pair of tights and wear them under your work clothes. It is
surprising how much warmer you will be. I used to wear them when doing the market stalls in the cold weather.
