Cita
posted on 2/10/04 at 10:24 AM |
Auto Darkening Helmet
Going to a wall markt today where they seemed to have ADH for sale for 25£!!!!
Works on solar cells.
I dont know what to look for but for this kind of money i guess i should take the flaws with it.
Let you know what this little bugger is all about.
madforfishing
posted on 3/10/04 at 06:25 AM |
At 25 Euros if they are any good, Cita you might get a few requests for postage and packing costs.
Let us know if it's any good. (If you don't get ARC-EYE and can type afterwards)
blueshift
posted on 3/10/04 at 09:17 AM |
I have one for 40 quid from a uk supplier (stand at donnington). I haven't used any other auto-darkening helmet but this one's a bit naff.
I describe it as being like the high contrast tunnel vision effect in the film "pitch black". you can see the arc and not a lot else,
everything is blue. makes going back to glass a luxury. OK for tack welds though.
Cita
posted on 6/10/04 at 06:49 PM |
I had my first go with the new helmet and for a novice like me it's a real luxuary item.
It sure makes life a LOT easier but i must say that it's a bit like blueshift mentioned in the above reply.
The overall view is a lot darker than with my conventional shield but i guess that experienced welders will have no problem with this.
All in all i consider it as an improvement.
posted on 8/10/04 at 06:52 PM |
Battery one off ebay
My mate Kev's bought one for £29 +p&p. He brought it round today for me to have a go and I was quite impressed with it. I was a bit wary of
it but it went dark quickly and was adjustable from 9 to 13 with a visible difference between the lighter and darker shades. You had to remember to
switch it on though but if the solar ones are as good I may invest in one.
Mark Allanson
posted on 8/10/04 at 07:05 PM |
Fine if you are welding alone, but in a work situation they are worse than useless, they darken everytime another welder flashes up!
paulf
posted on 8/10/04 at 09:00 PM |
Ive got a solar powered one and the main problem is that if left in the dark as in my locked workshop, it doesnt work properly unless welding in
bright sunlight. After it has been in the sun for a while it tends to work fine for a while until left again. I think that the solar cell must charge
an internal battery.
Apart from that is is very handy for tacking up and working under cars where its difficult with a hand held mask.
Paul.
You had to remember to switch it on though but if the solar ones are as good I may invest in one.
blueshift
posted on 8/10/04 at 10:22 PM |
hand held mask? that's crazy talk.. don't you have a glass full-face mask too? that's what I do most of my welding with.
always need two hands on the torch, dread to think what my welds would be like with only one. probably even WORSE
paulf
posted on 9/10/04 at 09:10 PM |
Yes i also have a full face glass mask, but if welding under a tin top i find it a pain to use for tacking etc as i allways end up working on ramps or
axle stands with no room to be able to swing it in and out of position.
Anyhow i always use the auto mask now , the hand held job is collecting dust, however i actually find it easier to hold the torch in one hand unless
doing long weld runs .
Paul.
andyps
posted on 10/10/04 at 05:17 PM |
Where from?
posted on 10/10/04 at 05:20 PM |
Read the title andy . I've seen some solar ones on there as well, so I'm watching to see how high they go.
splitrivet
posted on 11/10/04 at 09:40 AM |
Had my solar one from ebay last year £36 plus P&P.It arrived from the states and I didnt pay any duty which was a bonus.
The panel is very good but the mask itself's quality leaves a lot to be desired but I suppose that can be changed.
A word of warning tho my lad had one and left it in the garage over the winter,the frost totally killed the electronics in his.
Bob
ayoungman
posted on 20/10/04 at 08:48 AM |
welding
I've been welding for years so when I first used a self darkening shield, it was a revelation. For first timers, it must make placing the tip in
position much easier, I've also used the shield for arc welding and it helps in striking the arc too. Mine cost £100 approx.
"just like that !"
Terrapin_racing
posted on 20/10/04 at 10:49 AM |
Remember guy's - you get what you pay for! Check the technical spec and HSE compliance.
How much is new eyesight these days?
I eventually bought one compliant to UK standards but it was > £100
and to repeat a point mentioned early - don't leave it in the garage over winter - wrecks the lense and electronics (damp/cold)
Have fun
Cita
posted on 20/10/04 at 06:51 PM |
Cost of new eyesight approx 1200£ as per oct. 2003!
Had eye surgery on both eyes.World looks a different place and i'm much more ugly than i thought i was!!!!!!!
