Author: Subject: Which full head welding mask
DIY Si
posted on 10/4/14 at 11:48 AM Reply With Quote
Due to having a hole in the top of my head these days, I am in the market for a full head, auto darkening welding hat. But I've not used one, nor do I know anyone with one to give it a try before buying.
I've already got a flip up auto darkening type mask, but I need to cover the top of my head with something weld proof. I'm not looking to spend loads, and if there's something that I can wear under my existing helmet like a hood of some sort, that would be better/cheaper I assume. When it's cold I tend to wear a beanie hat under the mask, but they're no good at stopping splatter.
So basically, any suggestions?
Sun Tzu, The Art of War
MP3C
posted on 10/4/14 at 12:05 PM Reply With Quote
My friend just uses an old thickish cap worn with the peak to the back, said it worked fine when I mentioned it.
Minicooper
posted on 10/4/14 at 12:53 PM Reply With Quote
I've always used these, Kromer are the best, reverse it when your welding and the peak stops weld spatter going down the neck
http://www.ukwelder.com/shop2/shop_index.php?page=kromer_originals_menu
Slimy38
posted on 10/4/14 at 01:02 PM Reply With Quote
Looks like a decent bit of kit, I might pick one up myself. Even my welding tutor at college couldn't come up with anything better than a thick cap.
DIY Si
posted on 10/4/14 at 04:00 PM Reply With Quote
Thanks for the suggestions, and at £10 for the Kromer caps, cheaper than I had expected too!
jacko
posted on 10/4/14 at 06:36 PM Reply With Quote
I use the same good gear
