Mikef
posted on 29/10/14 at 01:04 PM |
blast cleaning
Hi All.
I am thinking of using some Techline satin black heat shield paint. However it says in there tech spec that the parts must be blast cleaned using
Aluminium oxide or fine Silica,and not glass beads or grit etc. I am in the SW and all the people I have spoken to do not use these products . Any
body know some that does. I do get to the Oxford area quite regularly so that's a possibility also.
posted on 29/10/14 at 04:07 PM |
Errr, what is it your going to paint??
Mikef
posted on 29/10/14 at 05:25 PM |
Its an exhaust manifold which is very near to the rear cockpit wall and even with a heat shield this season has crisped it. The coating is a ceramic
based one as far as I am aware and does actually reduced the temp emitted. Application is critical and whilst not an arm and a leg , you dont want it
coming off after you have sprayed it. You can get similar coatings done professionally, but you are talking about £250. So in true Locost spirit ,
thought I would have a go myself. I am also going to use some Zircotec heat shield sheet which gets very good reviews.
macc man
posted on 29/10/14 at 07:43 PM |
I bought some aluminium oxide grit from Machine Mart some time ago. If you have access to a grit blast gun you can do it yourself.
Mikef
posted on 30/10/14 at 07:29 AM |
Many thanks for this, will have a look.I have a feeling that the compressor I have is not big enough it has quite a decent tank and runs at 7cfm?
