qwerty_100
posted on 2/1/16 at 02:46 PM |
burtons hall efect speedo
Hi All
Firstly happy new year to every one, and now for the help. I have purchased a hall effect sensor from Burton power to fit my type 9 gear box . it
is has 3 wires
Brown/Black
Brown
Brown/Yellow
I believe the sensor is from a Ford Transit/Focus I can not confirm this a the part number has been ground away . I take it that brown is
negative and the other two are signal and power can anyone tell me how to test or point me in the right direction for a wiring diagram that has
correct colour codes I have googled it but have had no success many thanks.
Kev
[Edited on 2/1/16 by qwerty_100]
gremlin1234
posted on 2/1/16 at 04:08 PM |
try
Will connect to most Ford RWD gearboxes using part number REVT9-A. M18x1.5 thread. Total length 45mm. Wiring: yellow/brown - pickup; brown -ve;
brown/black +ve. 8 pulses per revolution.
strangely from
http://www.burtonpower.com/ford-electronic-speedo-sensor-revfss.html
big_wasa
posted on 2/1/16 at 04:44 PM |
When I did mine.
Black is switched 12v
Brown is earth
Yellow is signal out to your gauge
qwerty_100
posted on 2/1/16 at 06:16 PM |
THANKS TO YOU BOTH. Gremlin I was looking on the on-line catalogue and not the website (note to self must try harder) at least I can get this fixed
before M.O.T thanks again .
Kev
