chris68
posted on 7/8/16 at 10:34 AM |
Brake pipe and fittings
Decided to route one of the brake pipes using copper or similar from master cylinder to front t-piece, this is only going to be less than a metre
long.
Been looking for pipe and fittings and the inevitable search lead me to E-bay where kits are available for about £12 with M10 brass fittings and 25
metres of pipe - this is half the price of just the pipe at some other places! The E-bay shops are various generic motor factors.
So is this stuff any good? Has anyone used it? Or is a case of leave well alone and spend out?
Your thoughts?
Chris
joneh
posted on 7/8/16 at 11:25 AM |
I ordered my parts from Burtons. Personally I'd prefer to assume my brake fittings are from a reputable supplier....
40inches
posted on 7/8/16 at 12:23 PM |
Local Motor factor, you can see what you are buying. Our local one makes the tube to size with fittings, with no labour charge.
britishtrident
posted on 7/8/16 at 02:53 PM |
Copper pipe is not recommended you want Kunifier and a decent Flairing tool the best budget buy is the Powerhand or same tool under various
differenr brand names. Quality of the unions (usaully called Tube Nuts in the trade) isn't an issue but how well made the flairs are if you
want to seal first time.
[/I]
russbost
posted on 8/8/16 at 08:14 AM |
Have a word with Oliver at Furoreproducts,
Link to FP,
he'll make you a flexy stainless braided hose for around £20, why bother messing about with copper or kunifer, the flexy is far easier to route
& clip up neatly.
chris68
posted on 8/8/16 at 05:51 PM |
Thanks for the reply, yes the flexi types do look good - will look into this.
indykid
posted on 8/8/16 at 10:23 PM |
quote: Originally posted by britishtrident
Quality of the unions (usaully called Tube Nuts in the trade) isn't an issue but how well made the flairs are if you want to seal first time.
I've found anything from Northern Irish motor factors on ebay are utter garbage.
I've had female joiners with thread too shallow to let the flare seat even with DIN male unions, eccentric bores in male unions and half formed
hexes. I buy all brake bits from Clarik Engineering Supplies now. Perfect every time.
I'd personally rather use rigid pipe for chassis mounting, flexi where flexi is required.
posted on 9/8/16 at 08:30 AM |
When making brake pipes for my MK Indy I bought a reel of pipe (Copper IIRC) from my local motor factor. I formed the bends slowly by hand and used
my Dad's kit for forming the flares. The results worked perfectly and overall it didn't take long to do the job.
[img][/img]
