posted on 27/1/18 at 10:16 AM |
Small Surface Grinding Tips Please
Mornin
Does anyone have any hints our tips for getting these two lugs surfaces acceptably flat?
I have a pillar-drill... is anyone aware of there being any drill-bits that machine a flat surface?
Its only for mounting a bracket to take a handbrake spot-caliper, so perfection is not an issue. TBH, my flap-disc grinds are probably perfectly ok
for the purpose, but you know how it goes...
It's Evolution Baby!
40inches
posted on 27/1/18 at 10:22 AM |
I have used my pillar drill as a milling machine, using an end mill cutter and taking small cuts at a time.
Something like this eBay Item
[Edited on 27-1-18 by 40inches]
posted on 27/1/18 at 10:33 AM |
Cheers - was just looking at those.
posted on 27/1/18 at 12:11 PM |
How about using a flat surface ideally a surface plate and a sheet of emery paper to check the surface before any drastic machining?
mark chandler
posted on 27/1/18 at 12:14 PM |
If your pillar drill has a taper fit chuck forget it, the sideways force will knock it loose and the mill will drop into your work chewing it up, the
mill will also quickly become loose within the chuck having the same affect, this is why milling machines use collets and drawbars.
You would be better fixing some corse paper to a flat surface ideally glass and rubbing it across this.
From expensive experience, drills are good for drilling mot milling
[Edited on 27/1/18 by mark chandler]
40inches
posted on 27/1/18 at 12:30 PM |
In theory, yes But I have done a bit of milling on my cheapo Lidl bench drill, with a 1/2" chuck, removing a half mill at a time.
The best way is to cut vertically up to a stop, move the work piece along about 5mm, rinse and repeat A bit like engine turning.
It will need lots of lubricant.
posted on 27/1/18 at 01:20 PM |
Thanks guys... I guess the sanding approach is probably the safest as its not that far away from flat
ReMan
posted on 27/1/18 at 02:44 PM |
Alternatively some careful filing with a big file would have them flat and parallel
www.plusnine.co.uk
posted on 27/1/18 at 05:20 PM |
Yup - that would do it! Cheers
fazerruss
posted on 27/1/18 at 06:52 PM |
Or take it to someone with a milling machine. I could do it but im probably miles away.
[Edited on 27/1/18 by fazerruss]
"if assholes could fly this place would be an airport"
posted on 16/2/18 at 10:13 PM |
Just to complete the story - bit the bullet and took it to my local machine shop. Cost a tenner, but its perfect. Now all powder coated!
Thanks for the replies.
40inches
posted on 16/2/18 at 11:11 PM |
Brilliant
Angel Acevedo
posted on 17/2/18 at 12:43 AM |
.. Cost a tenner, but its perfect. ...
Locost solution for an expensive problem awaiting to happen..
Well done!
posted on 20/2/18 at 09:01 PM |
If it is critical piece, then don't - I've done the same and had the chuck come out and chew the aluminium piece.
