Slimy38
posted on 17/6/18 at 01:15 PM |
Bend or weld?
Out of interest, is it better to bend a single piece of metal or weld two pieces of metal at an angle? Or does it depend on the application?
cliftyhanger
posted on 17/6/18 at 01:51 PM |
Not an engineer, but thickness, type of metal and application will all have a bearing.
If steel, heat will mean the bend retains strength. But if you are thinking of something specific, we need details.
Slimy38
posted on 17/6/18 at 02:01 PM |
The three things that spring to mind are;
Steering rack mount.
Fuel tank.
Roll bar.
Assuming all are steel.
907
posted on 17/6/18 at 04:48 PM |
Always quicker to fold.
You can't fold every join, but by keeping welding to a minimum you'll get a stronger job in less time with less distortion.
I have to smile at six sided tanks that are constructed using 12 welds. Crazy
Paul G
Slimy38
posted on 17/6/18 at 07:03 PM |
That's what I was thinking of doing...
I had a go at making a metal folder, but I don't have a strong enough base or enough leverage to bend 1mm steel sheet. The steering rack
mountings were ok but I failed miserably when bending a sheet.
907
posted on 17/6/18 at 07:35 PM |
But your from the industrial north.
There must be thousands of benders, brakes & folders, both used and not so used, on your doorstep.
I bet you can't walk down your street without banging your ankles on an Edwards or equivalent.
Paul G
posted on 18/6/18 at 08:54 AM |
Paul G
A comment I was about to make myself - folding and bending generally reuires having the right machinery (and skills) for the job.
When it comes to fuel tanks I chose to buy one from MK Engineering for my MK Indy. Made to measure and fitted perfectly. A combinationation of
bending and welding IIRC. Possibly made for MK Engineering by another supplier.
jps
posted on 18/6/18 at 09:38 AM |
Wolverhampton is not 'the North'...
posted on 18/6/18 at 12:17 PM |
It is from here! Not saying anything about genders though.
posted on 18/6/18 at 12:35 PM |
Being from Hampshire I consider myself a southener.
To me Wolverhampton is the midlands!
That said I've spent plenty of time in the midlands and there are plenty of metal bashers around there.
YOUSAY54
posted on 18/6/18 at 03:43 PM |
Edwards
Live next door to a Edwards his name is Norman is that any good?
David Jenkins
posted on 18/6/18 at 03:47 PM |
All depends... is he a bender?
