Slimy38
posted on 24/11/20 at 11:07 PM |
Thermal camera alternative
I want to have a look at a few things heat related, for example I want to check my heated seats work ok, I could do with finding out why one of our
bedrooms is colder than others, that sort of thing. I was wondering about a thermal camera but they're not exactly cheap. Even the mobile phone
driven ones are three figures at least.
Is there anything else that could give similar results? I don't need the fancy graphics to see what is hot or cold, but I do want at least a
little bit of accuracy (down to half an inch or so). Any thoughts or recommendations?
mcerd1
posted on 25/11/20 at 12:07 AM |
if your looking for cost effective solution have you thought about infrared thermometers ?
I got one of these a couple of years ago and its pretty good for the money (although the price seams to have gone up £8 or so since...)
https://www.amazon.co.uk/gp/product/B01AT9TON0/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
i got mine for the garage a few odd jobs, but i've used it in the kitchen most often
just remember that any infrared sensor (basic one or full featured camera) will have issues with things that are reflective or transparent to IR (ie
most metal's reflect etc... but there are ways of dealing with that)
[Edited on 25/11/2020 by mcerd1]
Mr Whippy
posted on 25/11/20 at 12:11 AM |
I have one of those thermometer gun things with the laser dot. If you hold down the trigger it continuously reads what temp it sees. It's very
handy for scanning along walls looking for cold spots etc. I got it as a birthday present after some hinting but I don't think they are
expensive. If you point it at a clear sky it reads about - 50 or the temp of the clouds and at the stove goes over 800 deg. A meter away it's
about an inch area its looking at. Can spot if a cylinder is not running right or a brake is binding, electric connections in the house are over
heating, if the kids are trying to bunk of school with a alleged temperature... Loads of uses.
Slimy38
posted on 25/11/20 at 08:04 AM |
Aha, that's what they're called! I'd seen similar device on cooking programmes and even as Covid health checks, but didn't
know what they were called.
I think they might be the best option, especially with that continuous measurement option. I was kind of worried that I'd have to be fairly
close or the resolution wasn't good, but an inch area at a metre range sounds pretty usable.
Thank you both.
mcerd1
posted on 25/11/20 at 08:43 AM |
my one (in the link above) can do the continuous measurement while you holt the trigger
and has a 25mm dia. area at 300mm and 30mm dia. at 360mm - so thats about 83mm at 1m
ones more or less the same as that one turn up in Aldi / Lidl now and then too
ianhurley20
posted on 25/11/20 at 09:19 AM |
Mine cost £14.99 a couple of weeks ago at Lidl. At that price I wasn't expecting too much but its far more accurate than I thought. Instant
result on taking someones temerature, I don't have to bleed the radiators anymore as it shows a cold spot at the top if there is air in that
radiator, misfire on one cylinder at peak revs - temp reading shows which, adjust spark gap a little and it shows if that is a success. More useful
than I expected
Slimy38
posted on 25/11/20 at 09:24 AM |
than I expected
Oddly enough I've just managed to get back to my computer and Aldi/Lidl were going to be my first destination!
fregis
posted on 25/11/20 at 09:07 PM |
it is IR thermometer. bigger distance, less accurate reading, because sensor picking up wider area
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
