Author: Subject: New welder advice
locoboy
posted on 23/1/22 at 04:59 PM Reply With Quote
New welder advice
It's been a while since I needed/used the welder but dragged ti out form under the bench and the think just clicks when I pull the trigger, no wire feed at all.
It's a SIP migmate 130 and it has been woeful at best for the 15-20 years Iv'e had it, new liners, new torches, new wire feed rollers, erratic wire feed and now this.
I think it's time for her to go and be replaced by something a bit more reliable.
I use it once in a blue moon but maybe if I had a more reliable machine it would get used more .....
I don't weld 10mm thick stuff and on the same token I don't undertake car body repairs either.
bloody typical, I needed to do about a dozen tack welds to do a quick job, it took longer to get it out and set up then it would to have done the bloody welding!
Any advice welcome.
Locoboy
Mike Wood
posted on 23/1/22 at 08:40 PM Reply With Quote
I have not got an answer but have similar issues with my SIP Migmate 130 which replaced about 10 years ago a lovely old Cebora PocketMIG from the 1980s that worked beautifully but some kind person walked off with!
If I could somehow justify the expenditure I would want to take a look at a UK made Oxford MIG - https://www.oxfordwelders.co.uk/ I am at a loss what is a good budget option. Clarke any good these days? I wonder if Cebora offer anything suitable now?
Good luck.
Hopefully someone on here has some good suggestions.
Mike
[Edited on 23/1/22 by Mike Wood]
Slimy38
posted on 23/1/22 at 10:13 PM Reply With Quote
A second hand Clarke is still probably the most cost effective option in my opinion. I got mine for about £100 off Gumtree, the wire was rusty (and it needed a new liner because of it), but fresh consumables and a clean got it working really well. I also swapped the earth cable for something decent with a Dinse connector.
fazerruss
posted on 23/1/22 at 11:40 PM Reply With Quote
Oxford are great machines, built by TecArc in York. I have an Oxford Tigmaker that I use daily for my business. They a simple rugged machines built to last.
"if assholes could fly this place would be an airport"
posted on 24/1/22 at 04:19 PM Reply With Quote
Another vote for Clarke from me. I bought an ex-display 151TE a few years back and it works really well, even if left for a few months un-touched. Simple enough to setup and get going. Spares and support are readily available too.
MikeR
posted on 24/1/22 at 04:25 PM Reply With Quote
I bought a Clarke 150 en about 15 years ago. Think I got it vat free for under 200 quid. Never missed a beat.
Prior to that I had a second hand cebora 90 amp with no fan. I took the side off, put a massive fan next to it and worked it to death for 4 years. Lovely machine.
SJ
posted on 25/1/22 at 03:56 PM Reply With Quote
The smaller Clark ones have rubbish wire feeders. My 105 was dreadful until I replaced the feed unit with a cheapy Ebay one. For £13 it completely transformed the machine.
MikeR
posted on 25/1/22 at 04:17 PM Reply With Quote
So you have any links for an example feeder?
Don't need one but send cheap enough to keep as a spare
SJ
posted on 25/1/22 at 04:30 PM Reply With Quote
This one - price has changed a bit
It was pretty much a straight swap - just had to drill a couple of extra holes
