iscmatt
posted on 10/8/06 at 07:18 PM |
BUG-ER.....
To fit my K&N filter i had to thread three holes on my carb, two i did by hand (pliers) as with the first one i used the drill and drilled the
hole bigger not threaded.
So... how can i rectify it, is putting some steel putty in the hole drill and re-thread a good path or is there a tried and tested way!
help!!!
Regards Matt
nib1980
posted on 10/8/06 at 07:25 PM |
what about tapping it at the size you've drilled it (too big) and then fitting a helicoil to reduce the thread to what you want?
just a thought
omega0684
posted on 10/8/06 at 07:35 PM |
how about just re-threading the larger hole and then just use a bigger threaded
screw
just another thought
iscmatt
posted on 10/8/06 at 07:40 PM |
No can do. the screw is double-ended so i need to sort out the whole really.
tks
posted on 10/8/06 at 07:56 PM |
place a nut instead of thread??
make a pic sow we can advise better
i think that welding a nut or refilling with weld will be the best option saying that you have to be lucky with the material your carb is from..
else i would just go to the scrapyard...
many times a bad repair can be a week spot...
but in this case maybe it isn't
make a pic it judge better...
Tks
p.d. the best option sow far!!
make out of 2mm stainless a gasket! weld on its back the nut round of the nut place it in the hole drill the holes of the rest of the holes etc.
etc.
and you can screw!!
but it will depend a bit on distances...
Tks
[Edited on 10/8/06 by tks]
The above comments are always meant to be from the above persons perspective.
ned
helicoil it.
beware, I've got yellow skin
rayward
posted on 10/8/06 at 08:15 PM |
Just fill the hole with DEVCON and re-drill it the correct size.
Ray
[Edited on 10/8/06 by rayward]
Chippy
posted on 10/8/06 at 09:28 PM |
JP Weld, works wonders, can be drilled and tapped. I used it to repair a chunk out of a boat prop, still going strong. Regards Ray.
907
posted on 10/8/06 at 09:36 PM |
Drill and tap bigger.
Screw in an ally bolt with thread lock, e.g. bike bodywork bolt.
Flush off and drill and tap the right size.
hth
Paul G
JohnN
posted on 10/8/06 at 09:50 PM |
Use a nut & bolt, or just use the two that are OK, ignore the third. I've only used two of the three bolt holes for a K&N on a TLD carb,
perfectly robust.
RazMan
posted on 10/8/06 at 09:53 PM |
There was some low temp (blowtorch)alloy welding wire at a few of the shows. Can't recall the name but it certainly looked ideal for this job.
Flow it in and drill & retap again.
Raz
iscmatt
posted on 10/8/06 at 10:39 PM |
Wow now thats what i call a reply! i'll work on it tommrow, thanks for all your help!
posted on 11/8/06 at 08:47 AM |
lumiweld/technoweld is the stuff.
it requires a fair bit of heat though - so you'd best strip the carb of any bits that can melt and do it onn top of a cooker tpo aboid
distorting the body.
apparently in the instructions I have, you can stick a bolt in the molten metal and have a threaded hole.
agian without pic of your problem, I cannot know for sure but to hold an air filter you don't need much strength so I would try this chemical
metal stuff - supposed to be able to drill & tap and is meant to be as strong as metal
NS Dev
posted on 11/8/06 at 10:51 AM |
I wouldn't even think of warming it to repair it, chance of making a small cock up into a big one!
They are about M6 size aren't they? few options, small bolt, nut and washers (plus loctite!) or a big self tapper and some loctite!
Its a bodge but then its not doing a lot!
Bluemoon
posted on 11/8/06 at 01:49 PM |
I agree with NS Dev on this, so long as none of the repair will end up being drawn into the carb if it fails, nackering a whole lot more than just the
carbs!
[Edited on 11/8/06 by Bluemoon]
posted on 17/8/06 at 02:41 PM |
...... and? Was there a happy ending?
