iiyama
posted on 2/12/06 at 04:59 PM |
diff mounting.
If its broke, fix it. If it aint broke, take it apart and find out how it works!
posted on 4/12/06 at 11:28 AM |
quote: Originally posted by iiyama
The Ti Im using is equivalent to 8.8 grade steel bolts.
Evertything thats stressed has Ti bolts, everything that isnt has Aluminium bolts. Weight mah boy....or lack of it! Ti is 40% less then steel.
Aluminium is about 60% less.
Saved over 3/4kgs alone on the diff...) so over all should save about 2kgs or more.
No its not cheap, however its a lot cheaper then getting lots more grunt from the engine! Also has the benifits that it dosent corrode like steel so
it looks pretty!!
2 kgs how is is it going to cost you?
you can get same effect by eating less pies, removing the passenger seat or puttin in 1/2 a gallon of fuel.
Assuming your car is really light, say 400 kg which is unlikley, you are talking of 0.5 % - your 0-60 times will tumble.
iiyama
posted on 4/12/06 at 11:44 AM |
and if I do all three plus Ti then thats a BIG saving!!!!
