Author: Subject: paint spraying
blakep82
posted on 31/3/07 at 10:58 PM Reply With Quote
paint spraying
bought a compressor months ago for paint spraying and air tools etc, but haven't actually tried spraying yet.
has anyone got any good tips? like what paint/thinners/consumables do i need? how do i mix the thinners with paint? what paint (i know of 2 pack, cellulose etc, but i was talking to a bodyshop and they said they use waterbased paint. what does this come under?)
[Edited on 31/3/07 by blakep82]
________________________
gazza285
posted on 31/3/07 at 11:04 PM Reply With Quote
Yeh, get somebody who knows how to do it properly, it's much much harder than it looks.
blakep82
posted on 31/3/07 at 11:35 PM Reply With Quote
i want to know how to do it properly, thats why i'm asking, and want to start and learn, after all, even the pro's have to start off not knowing anything, don't they?
anyone got any useful advice?
big_wasa
posted on 1/4/07 at 08:16 AM Reply With Quote
Patiance........You will need loads.....
As said the finish is all in the prep work. So you need patiance to keep going and not say bugger it that will do
Be patiant and give the paint plenty of time to dry before handling it. Gues how I know this
[Edited on 1/4/07 by big_wasa]
posted on 1/4/07 at 10:15 AM Reply With Quote
You can prep all you want and then f*ck it up by not thinning enough, spraying from too far away, not reading the spec sheet for the paint etc. I don't paint much that matters and I usually paint outside, mainly with cellulose these days. Greenfly are my main problem but not at this time of year, I find that they cut out after the paint dries and only the feet are left. Get some old cardboard boxes, flatten and tape them to the back of the door to practise on.
ecosse
posted on 1/4/07 at 11:14 AM Reply With Quote
If you are spraying in somewhere with a concrete floor, wash it down with water first, it keeps the dust down.
And get spec sheets for whatever paint you are using, and read them
Alex
blakep82
posted on 1/4/07 at 01:35 PM Reply With Quote
i think i read somewhere that if you make the car connected to -ve (by a battery charger or a bettery) then the paint is attracted to it? could be useful for spraying a chassis perhaps? Is this true? or just likely to attract dust and other nastyness?
Confused but excited.
posted on 1/4/07 at 09:47 PM Reply With Quote
Works okay if you can lay your hands on a 35,000 volt battery.
blakep82
posted on 1/4/07 at 10:12 PM Reply With Quote
got some electric pylons not far from me, I'll hook one up.
damn. they're AC aren't they?
davie h
posted on 3/4/07 at 07:13 PM Reply With Quote
i have just painted my tintop in the garage at the house looks as though its not to bad a job i got advice from a mate who knows what to do and it has turned out alright apart from when i had just finished the clearcoat and a small square of paper fell of a shelf and landed on the wing aaaaahhhhhh f%Łk but it will rub out also bits of dust etc in clear coat but thats painting in a garage for you give it a try you dont learn if you dont try
chrisg
posted on 4/4/07 at 10:28 AM Reply With Quote
There's a ten page how-to in the new book by a professional if that's any use?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
blakep82
posted on 9/4/07 at 07:04 PM Reply With Quote
excellent! thanks everyone!
was wondering about the processes also, priming, flatting with wet and dry (how many coats?), how many coats of paint, gloss?
stevebubs
posted on 10/4/07 at 11:29 AM Reply With Quote
How long does cellulose take to dry when left naturally at an ambient 20degC? Thought it took a lot longer than (for example) 2pack
posted on 10/4/07 at 07:32 PM Reply With Quote
I usually leave mine for an hour before I take any masking off then wash it down next day. I don't do any cutting or finishing till it's been on a couple of weeks. That's using standard thinners. If you use faster flash higher gloss top coat thinners you are talking minutes to actually dry.
