smart51
posted on 18/4/07 at 12:18 PM |
What is an F type torque wrench?
The Yamaha service manual specifies the use of an F type torque wrench for tightening the conrod big end bolts. What is an F type torque wrench?
andyace
posted on 18/4/07 at 12:33 PM |
linky
http://www.millsltd.com/productDetail.cfm?partno=H00-3500
posted on 18/4/07 at 12:43 PM |
One that goes "click" ?
smart51
posted on 18/4/07 at 01:21 PM |
That would seem to make sense as the instructions say once you have passed 20Nm you must not stop ontil 36 Nm is reached. If you stop you must
slacken to less than 20Nm then do it again.
I guess I could use a clicky type and set it to 15 or 17Nm then reset to 36 and do it in 1 sweep.
posted on 19/4/07 at 09:23 AM |
When we did the head gasket on a nephew's car it was like a black magic spell tightening the bolts down, tighten to 50psi then leave for 10
minutes then tighten to 75psi and turn round 3 times chanting the name of your first born with your eyes closed, then tighten another 90°. They were
about 90psi when they were done.
