Macbeast
posted on 26/7/07 at 12:41 AM |
Brazing ?
Not wanting to get into welding kit expense, I seem to recall that you can do brazing with the higher temperature gas cannister torches.
Would this be ok for sump shortening and moving oil filler neck on rocker cover ?
big_wasa
posted on 26/7/07 at 05:42 AM |
If you have an arc welder I have a Brazing atachment that you can have
designer
posted on 26/7/07 at 06:20 AM |
Brazing is OK for this.
britishtrident
posted on 26/7/07 at 06:29 AM |
Yep More than OK for this type of job.
Silver solder is also fine.
With both processes everything needs no be prpoperly cleaned before you start, and use the correct type of flux --- usually Borax powder flux or
coated rods.
However brazing or silver soldering a large work piece using a MAP gas blow lamp isn't really on as the they don't give concentrated heat.
[/I]
caber
posted on 26/7/07 at 07:09 AM |
How can anyboby who messes with cars not have a welder these days!Go on get yourself a MIG set or even better a cheap Chinese TIG set, you will be
amazed how much you will use it, and how many new friends you get who just need a quick patch on something or a lwnmower handle fixed!
Caber
Macbeast
posted on 26/7/07 at 07:15 AM |
TY all.
Caber, I'm coming up to Scotland next month. I'll bring the lawnmower handle, OK ?
mookaloid
posted on 26/7/07 at 08:00 AM |
I fixed a mates lawn mower handle with a blob or two from the mig a couple of weeks ago
David Jenkins
posted on 26/7/07 at 08:06 AM |
<snip>
Silver solder really needs a special flux for best results. It's also finnicky about the cleanliness of the area to be joined - it's got
to be spotless. Finally, it's bl**dy expensive!
A friend brazed the bottom of a sump for me, but oxy-acetylene was required, to get enough heat into the joint area without overheating the whole
sump. The metal has to be heated to bright orange for brazing, and that's not easy with a conventional gas torch!
posted on 26/7/07 at 10:01 AM |
Anyone on here not fixed a lawnmower handle in the last month please leave the forum I did one 3 weeks ago. I used my old Portapack to put a patch
on the van the other day as well. I definitely could not cope without a welder of some description. If you want to use Wasa's brazing attachment
there's an old oil cooled arc welder in the shed here.
David Jenkins
posted on 26/7/07 at 10:30 AM |
I replaced the blade on my lawnmower last week, but that involved a spanner, not a welder.
Does that count?
iank
FWIW you can braze with a mig welder - not that that answers the original query
http://www.mig-welding.co.uk/brazing.htm
p.s. for the pedantic he's really talking about bronze welding not brazing, but the terms tend to get commonly confused. Caged seem to use this
for putting together Caterham chassis.
[Edited on 26/7/07 by iank]
Anonymous
lsdweb
posted on 26/7/07 at 11:43 AM |
I dropped a valve (actually the seat fell out) on my lawnmower last week - a few days before bending 12 valves on the race car. I have to fix both so
does that count??
graememk
posted on 26/7/07 at 12:04 PM |
i ran over a garden light with the mower the other sunday.
not that its anything to do with brazing
awinter
posted on 26/7/07 at 12:46 PM |
Ill get me coat
I don't have a mig or a lawn mower.
Can I stay?
iank
posted on 26/7/07 at 12:55 PM |
My lawnmower isn't used enough to break a handle.
It's also only got an electric motor <oh the shame> and plastic blades <sob>
Anonymous
David Jenkins
posted on 26/7/07 at 01:23 PM |
Can I stay?
Sorry, no.
We do have standards to maintain...
posted on 26/7/07 at 02:47 PM |
No I think he means brazing in the true sense of the word, he's joining two bits of plate not building his chassis.
Here is a bit of a guide.
