ditchlewis
posted on 12/9/07 at 07:49 AM |
What is a Flat Drill
I have to re drill the base of my starter motor. it is retained with a allen headed bolt that is flush with the face of the base.
the man at cambridge motorsport said i needed a flat head drill. what is one of these?
i know that i have to drill a hole for the bolt but then i have to ream out the base to get the bolt to sit flush with the face.
is a flat head drill bit one of these?
Ditch![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
![](/galpreviews/a616525-flat drill.JPG) ![Rescued attachment flat drill.JPG](/gallery/a616525-flat drill.JPG) Rescued attachment flat drill.JPG
Hurdsey
posted on 12/9/07 at 07:58 AM |
Nope thats a Flat Bit for wood.
I'm not an engineer but I think a flat head drill is designed to drill holes with a flat bottom instead of a bevelled bottom iyswim. I'm
sure a good Engineers merchants would stock them.
It may be reffered to as a Reamer but I'm not sure.
Mark Allanson
posted on 12/9/07 at 07:59 AM |
..or perhaps an end mill
designer
posted on 12/9/07 at 08:00 AM |
The drill you showed is for wood.
A flat drill the bloke is talking about is one used when the hole does not go through the piece being drilled and it leaves a flat bottom to the
hole.
Where are you drilling on the base? Are you just making another mounting hole?
JAG
posted on 12/9/07 at 08:02 AM |
It's not referred to as a Reamer.
But it is a drill designed to cut a flat bottomed hole.
Be very careful when using it - the shorter cutting edge (than a normal drill) means they need a lot of torque to drive them and can only cut
relatively slowly
Justin
Fred W B
posted on 12/9/07 at 08:16 AM |
Its called a spot face tool.
If you can't find one can you change to a bolt with a countersunk head, as a chamfer tool is easier to find?
Fred W B
[Edited on 12/9/07 by Fred W B]
You can do it quickly. You can do it cheap. You can do it right. – Pick any two.
ditchlewis
posted on 12/9/07 at 08:31 AM |
many thanks lads![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
the alloy mounting plate on my starter motor needs moving round. the existing holes have a flat bottom to them to seat the bolt flat and flush to the
face.
Fred's idea sounds good.
the question i now have is in a high torque application is option A (see below) more likley to fail than the existing option?
ditch![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
[Edited on 12/9/07 by ditchlewis]
ditchlewis
posted on 12/9/07 at 08:32 AM |
here is the pick
Ditch![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
![](/galpreviews/a616543-options.JPG) ![Rescued attachment options.JPG](/gallery/a616543-options.JPG) Rescued attachment options.JPG
posted on 12/9/07 at 09:06 AM |
quite possibly but not that you would ever achieve it.
basically, and I could be wrong, the weakest part of the bolt is the thinest part i.e. the threaded section - that would where it would fail so the
shape fo the bolt head does not matter.
Mr Rob
posted on 12/9/07 at 10:11 AM |
If you have a bench grinder you can grind a normal drill bit flat. Drill the hole first with a normal drill an then go in with your new ground bit....
job done.![](/images//smilies/bigsmile.gif)
ditchlewis
posted on 12/9/07 at 11:08 AM |
just remembered that i bought some bits very early on in my build that may do the job.
i will have to look and measure what i have.
i will have to drill a hole for the bolt first then i will have to use these bits (see below).![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) . these bits have a flat face on them.
![](/galpreviews/a616604-bit.JPG) ![Rescued attachment bit.JPG](/gallery/a616604-bit.JPG) Rescued attachment bit.JPG
iank
posted on 12/9/07 at 12:04 PM |
That looks like a lip and spur drill (flat with a spike) I think they are just for wood (also called a dowel bit IIRC).
Anonymous
tks
posted on 12/9/07 at 12:45 PM |
job done.
i wouold try this idea, because with a flat drill its not easy to pick the right place of drilling, saying that, when you cut down a normal drill, you
don't leave a cutting edge.
i would go for the countersunk screws.
The above comments are always meant to be from the above persons perspective.
timf
posted on 12/9/07 at 01:07 PM |
you need something like this
http://www.screwfix.com/search.do;jsessionid=A0P1YSBZSQFOYCSTHZPCFFI?_dyncharset=UTF-8&fh_search=counterbore
or from ebay
http://stores.ebay.co.uk/Mattools_CUTTING-TOOLS_Countersinks-Counterbores_W0QQcolZ4QQdirZ1QQfsubZ3277677QQftidZ2QQtZkm
looks like
[Edited on 12/9/07 by timf]
A prisoner of war is a man who tries to kill you and fails, and then asks you not to kill him."
- Sir Winston S. Churchill, 1952
ditchlewis
posted on 12/9/07 at 01:28 PM |
iank
the above drill was for steel and was titanium, it went through steel like butter![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) .
problemis that i have used them all alot and they are probably blunt now![](/images//smilies/sad.gif) ![](/images//smilies/sad.gif) ![](/images//smilies/sad.gif) and they were about a ten to fifteen quid each. ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
ditch![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
posted on 12/9/07 at 01:43 PM |
when I had to do something like this i.e. fltten out hte bottom of a blind drilled hole, I used end mills.
mmart do a set from 4 to 10 mm.
Alan B
posted on 12/9/07 at 02:08 PM |
As Timf shows the correct tool is called a counterbore......a spotface is essentially a shallow counterbore used on castings or rough surfacee to give
a true seating face.
They can be bought in sets with interchangeable pilots or individually.
907
posted on 12/9/07 at 04:02 PM |
Mr Rob has the locost option.
In with a normal drill to below the surface, then take out the angle with a flat one.
A drill is a drill. How you just sharpen it depends on what you want to do.
Hth
Paul G
![](/galpreviews/a616702-drills-tx-s.jpg) ![Rescued attachment drills-tx-s.jpg](/gallery/a616702-drills-tx-s.jpg) Rescued attachment drills-tx-s.jpg
NS Dev
posted on 13/9/07 at 05:46 PM |
as Mr Rob and 907 said, just grind a std drill bit flat at the end.
I have used this to do spot facing many times, as spot face cutters are very expensive!!
MikeRJ
posted on 20/9/07 at 09:43 PM |
But they do work on metal with a bit of modification! My spot weld cutter fell to pieces during a job some time back and I modified one of these wood
bits to make the spike shorter and it ripped through dozens spot welds with little problem. It was a reasonably quality drill bit though, not a
cheapy.
iank
posted on 21/9/07 at 09:35 AM |
Using them as a spot weld cutter would be fine I'd image, but they bind if you try and drill thick metal due to the cutting geometry.
http://en.wikipedia.org/wiki/Drill_bit
The one's I've got scream into wood with the lightest pressure, they actually seem to tunnel into the hole on their own.
Anonymous
Vindi_andy
posted on 21/9/07 at 12:25 PM |
when we had to use flat ended drills at college during my apprenticeship(many moons ago) we always had to drill the hole with a standard drill first
then just flatten the bottom of the hole with the flat drill
Part of the problem I experienced was as someone else said earlier about the centreing also if you dont have a pre drilled hole the bit has a tendecy
to wander
