speedyxjs
posted on 23/9/07 at 06:36 PM |
Stone cutting disk
Any good for cutting metal?
mookaloid
posted on 23/9/07 at 06:42 PM |
Absolutely not.
You should only use the correct disc for the job.
Very dangerous if a disc explodes
cheers
Mark
gazza285
They will, but are not recommended due to the temperatures that are generated being much higher than the disk is designed for. Takes longer too.
posted on 23/9/07 at 06:48 PM |
I used a stone disc cutting a 2" by mistake and it ragged up and exploded...
Don't even try it... metal discs are cheap enough from B&Q.
speedyxjs
posted on 23/9/07 at 06:54 PM |
Ok just i had some free with the grinder and wasnt sure if i could use them
posted on 23/9/07 at 06:56 PM |
Stone cutting disks in Stihl saws will cut any material known to man as long as it's on a building site. I've seen them used to cut RSJs,
steel reinforcing, plastic drainpipe and anything they were resting on at the time
Mole
posted on 23/9/07 at 07:39 PM |
I used stone cutting disks to cut ali. I'd heard that the wouldn't suffer the clogging and exploding problem steel cutting ones do. Might
not be true but they did work.
Alex B
posted on 23/9/07 at 07:52 PM |
Not telling you to do it...but I`ve bin using them for years. 12 " in a sthil will eat through metal AND last longer. My local scrap man uses
nowt else. Not a clean cut.but is it ever with carbo blades?
Alex
