contaminated
| posted on 11/7/08 at 02:30 PM |
Cutting ABS
All
What's the best method for cutting 2mm ABS - which I'll be making new interior panels out of. Was thinking a jigsaw - but what type of
blade?
many thanks
smart51
| posted on 11/7/08 at 02:33 PM |
Slow speed. Too fast and the plastic fuses behind the blade.
Mr Whippy
| posted on 11/7/08 at 02:37 PM |
it is quite amusing to pull the blade out and find it all fused back together
A course blade works best but can grab and crack the plastic so go slowly, fine blades are useless and generate too much heat
[Edited on 11/7/08 by Mr Whippy]
contaminated
| posted on 11/7/08 at 02:41 PM |
OK, thanks guys. I'll get a selection and practice!!
whitestu
| posted on 11/7/08 at 02:47 PM |
I cut my 2mm dash with a jigsaw and it was fine - I used a fine blade at full speed and went through dead easy.
Perhaps on thicker stuff it may get hot but on 2mm for me it was no problem.
Stu
Mr Whippy
| posted on 11/7/08 at 03:08 PM |
Stu
yeah 5mm or so is a nighmare
| posted on 11/7/08 at 03:11 PM |
2mm abs will score with a craft knife and cut through with two or three strokes if you are cutting straight lines.
thunderace
posted on 11/7/08 at 04:36 PM |
i always use a grinder ,try it it works great i seen a guy in a plastic factory useing one years ago he told me it works great and it dose.
Chippy
| posted on 11/7/08 at 09:58 PM |
If you have got one of those squeeze trigger spray bottles, like you use for spraying in the garden. They work quite well at keeping the temp down,
just a quick spray on the material and the blade now and again, and it will cut clean. At least it works for me, Cheers Ray
